Author Topic: Rear Wheel Cylinders  (Read 1472 times)
Offline MWM
« on: December 01, 2012, 03:42:28 PM »
Hello!
I have a nine axle with the 10x2.5 rear brake drums. What is the correct wheel cylinders to work with these drums? Thanks!
Offline s2ms
    • 6S1757 Info
Re: Rear Wheel Cylinders
« Reply #1 on: December 07, 2012, 02:11:12 PM »
Sounds like you are referring to the early Shelby setup. If that's the case the standard Mustang V8 29/32" cylinders should work, that's what the 65-66 GT350's used. Ford part numbers C3OZ-2261-B and C3OZ-2262-B.
Some people believe the early GT350's used 15/16" cylinders since the 10x2.5" rear setup was sourced from the Fairlane wagon and that's what they had, but so far every 65-66 GT350 owner I've spoken with that still has the original rear cylinders have the 29/32" ones.
Dave
Offline MWM
« Reply #2 on: December 10, 2012, 06:17:59 PM »
Thank you Dave!
That's what I needed to know. I mic'd mine out and they match.
