Author Topic: 64-66 heater box finish restoration  (Read 2278 times)
Offline ExportMach
« on: November 18, 2012, 02:28:28 PM »
I glass beaded the paint/corrosion from the doors and did not protect the fiberglass case. The surface looks scuffed in a few places, any suggestions as to how I could restore the finish (nothing elaborate, I was thinking of rubbing some black shoe polish on some hidden area to test that. Maybe some 2000 grit sandpaper and some 3-in-1 oil?).
« Last Edit: November 18, 2012, 04:34:04 PM by ExportMach »
Mark C
Re: 64-66 heater box finish restoration
« Reply #1 on: November 18, 2012, 02:53:39 PM »
I restore heater boxes by glass beading and then using a semi-gloss clear paint.
Offline ExportMach
« Reply #2 on: January 28, 2013, 08:08:09 AM »
After a lot of thinking and looking I came up with the idea of using black shoe polish. One coat makes a big difference but another coat or two really coveres the scuffed fiberglass. Attached are the 'before' and 'after' pics. I am waiting on the new blower motor to complete the heater box resto. More pics to follow.
« Last Edit: January 28, 2013, 08:59:24 PM by ExportMach »
Mark C
Offline Oz390
« Reply #3 on: April 08, 2013, 11:30:45 PM »
Thinkin' show polish might not be the best long term solution.  I use vinyl dye, satin black, spray on a rag and wipe light coats to build to the color you want. for a couple really bad ones needing a lot of fibergalss reapire, just spray.  The satin is a bit too dark, but the best I could find to get "close" as the originals have a grey-ish cast and not quite full black.
8R03S : 76A I 2A 15M 72 5 U
« Reply #4 on: April 09, 2013, 06:10:24 PM »
Thinkin' show polish might not be the best long term solution.  ..........
Used/applied it 5 years ago - still holding up well. Not allot ;) of sun exposure nor wear in that location.   IF there was any I would expect I could simply wipe it with another application and things would look like they did.
Just what worked for me on a case needing no repairs
