Author Topic: 1970 Mach 1 gas tank  (Read 5055 times)
Offline 70Twister
« on: November 14, 2012, 09:49:26 PM »
Need to know if the factory gas tank had a drain plug or not in my 1970 Mach 1 Dearborn with Oct. build date!
And best place to get the new gas tank that I need!
70Twister
351C Dearborn Build date 10/13/69
Re: 1970 Mach 1 gas tank
« Reply #1 on: November 14, 2012, 10:40:28 PM »
no drain plug by that date
Offline app01
« Reply #2 on: November 15, 2012, 09:46:00 AM »
Adding to this, who makes the most accurate gas tank for a 1970?
Same gas tank used in  70 Mach 1, and Boss 2's,  correct? (Excluding California cars)
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
« Reply #3 on: November 15, 2012, 09:47:11 PM »
Not sure - haven't purchased one for a while. Hopefully someone with recent experience will provide some good info for you
Yes all non - Calif emission tanks would have been the same
Offline rayms69
« Reply #4 on: November 16, 2012, 10:10:57 PM »
mine is a 70 scj R code, build date 10-26-1969 Dearborn, has a drainplug, have the original tank, NOS is most accurate have seen on EBay if you got the money
« Last Edit: November 17, 2012, 06:17:05 PM by rayms69 »
10-26-1969 Dearborn 428 SCJ auto
« Reply #5 on: November 16, 2012, 11:43:34 PM »
mine is a 70 scj R code, build date 10-26-1969 Dearborn, no drainplug, have the original tank, ..........
Interesting - What is the date on the tank?
Offline rayms69
« Reply #6 on: November 17, 2012, 06:12:22 PM »
i will take a look first chance i get, its not on the car, too much risk with it being so old and cruddy inside, is it stamp in a certain spot, my tank does have a drain plug, i misspoke
« Last Edit: November 17, 2012, 06:16:11 PM by rayms69 »
Offline TLea
« Reply #7 on: November 17, 2012, 10:27:02 PM »
i think you'll find most NOS ones have a different welding pattern than  assembly line. The American Designer repops are actually very nice but lack the original niterne finish. If anyone knows ofc a NOS no drain plug for sale let me know
Offline app01
« Reply #8 on: January 02, 2013, 06:19:45 PM »
Tim,
I did end up locating a NOS tank for my 70 B2, and everything I have looked at so far, ribs,  shapes, dimensions etc. look exactly like my original.
You mentioned that the welding pattern  is different between the two. I need to scrape undercoating/paint off of my original to see the weld, but can you please elaborate on what the difference is?
Tony
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
Offline TLea
« Reply #9 on: January 03, 2013, 07:38:24 AM »
On an original the welds cross over each other at the corners. The service pieces are a continous weld that round the corners
http://www.ebay.com/itm/1970-NOS-FORD-MUSTANG-BOSS-302-SHELBY-428-CJ-MACH-I-GAS-TANK-/290830207433?_trksid=p2047675.l2557&ssPageName=STRK:MEWAX:IT&nma=true&si=EKlUO9g9vHdxggs%2BNc6FLAVUBi0%3D&orig_cvip=true&rt=nc
I want to correct my earlier statement as well. The originals were terne finish, not ni-terne. The newer repops are ni-terne which is terne (lead/tin) with nickel added
Offline app01
« Reply #10 on: January 03, 2013, 07:53:25 AM »
Thank Tim. That  was helpful.
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
Offline app01
« Reply #11 on: January 03, 2013, 04:05:28 PM »
Tim,
I pulled out a picture of a 69 Mach 1 Survivor that I sold this past summer,  and I see what you are talking about as far as the weld. I never noticed that weld detail. Even though this is a 69 and the tank is slightly different, I attached the picture as a reference to others and you can see the crossed welds at the far corners.
Tony
« Last Edit: January 03, 2013, 05:49:58 PM by app01 »
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
