Author Topic: Which Pump?  (Read 4013 times)
Offline Andrew@MagMustangs
    • MagMustangs
Which Pump?
« on: November 12, 2012, 06:44:51 PM »
C8AE-J or C8OE-D Water Pump for 68 302 4V? All the Date Codes on the Motor are 7M. December, 1967
Offline TLea
Re: Which Pump?
« Reply #1 on: November 12, 2012, 07:25:54 PM »
J
    • MagMustangs
Re: Which Pump?
« Reply #2 on: November 12, 2012, 08:27:43 PM »
Perfect! Thanks Tim! The water pump is the only non-original piece on this 60K original mile J-Code.
Offline TLea
Re: Which Pump?
« Reply #3 on: November 13, 2012, 08:51:49 AM »
I've never seen the C8 H on a J code but they were used on 69 Boss 302s
Re: Which Pump?
« Reply #4 on: November 13, 2012, 03:54:12 PM »
Per Bob Mannel's book, "Mustang and Ford Small Block V8", the casting number should be C8OE-D, and his disclaimer states that C8AE-J is a replacement pump (Appen E, pg E-6). This caught my eye as I have a rebuilt pump on the shelf with casting C8OE-D. I can't find a traditional date code on it.
Re: Which Pump?
« Reply #5 on: November 13, 2012, 06:48:22 PM »
I have versions of both of these here at work. The C8AE-J has an additional drilled and tapped hole in the one boss (on the one I have here).
The difference between C6OE-A and C8OE-D is the size of the weep hole. 1968 is larger.
    • MagMustangs
Re: Which Pump?
« Reply #6 on: November 13, 2012, 11:07:41 PM »
I don't usually find date codes on the pumps either, although I'm pretty sure I have seen some with date codes, not necessarily C8- pumps, but most of them I have had weren't dated. So, a Non Dated pump would be fine for me as long as it is the Factory Correct Pump.
I would like to make sure I source the Factory Correct Pump for this motor, it might eventually be Concours Judged. Its the only thing besides a Carb that is not correct. The Motor had an 85-86 5.0 Holley Carb on it. I got rid of that and would like to also find a correct carb but thats a Needle in a Haystack kinda thing.  ;)
I also posted a wanted ad for a pump, so if you have one available then please PM me.
Offline TLea
Re: Which Pump?
« Reply #7 on: November 14, 2012, 12:03:49 AM »
I had the original pump off my 350 rebuilt and it is a J. Also have another J code here thats never been apart and its a J
Offline DWhitaker
Re: Which Pump?
« Reply #8 on: November 18, 2012, 09:22:40 PM »
I have 2 J pump cores and have read somewhere that the C8AE-J were for A/C cars. Anyone else ever heard or read this? On date codes, I don't think any C6 or C80E-D had cast date codes.
    • MagMustangs
Re: Which Pump?
« Reply #9 on: November 18, 2012, 10:54:35 PM »
I was thinking along those lines also. Tim, are either of yours from A/C cars?
Re: Which Pump?
« Reply #10 on: June 14, 2016, 09:21:37 PM »
I searched this old thread for information on C8AE-J water pump. I was working on a 68 J code engine today and noticed that the heater hose port on it has a larger diameter tube on it than the other models of water pumps I have seen. May be it is a higher volume pump than the other and that is why it was used on AC cars and extra cooling car. Just a thought
