Author Topic: '65 Alignment of Hood & Headlight Door  (Read 11082 times)
Offline buckeyeresto
Re: '65 Alignment of Hood & Headlight Door
« Reply #15 on: November 28, 2012, 06:54:27 AM »
The first thing to check is make sure that your part numbers match up if you head light assembly is a "A" part number "B" part number "C" and "D" head light buckets that have a B part number don't fit together to well with a head light extension of a "C" part number its all gota match
thanks
Offline Skyway65
  • Gold Level Subscriber
« Reply #16 on: November 30, 2012, 12:22:53 PM »
Nate-  Another detail to check out.  I've been away from the car project recently.  Too many other things happening this time of year.  I'll be sure to check the "A" "B" "C" and "D's".   Thanks--Gary
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline C5ZZKGT
« Reply #17 on: January 28, 2013, 09:23:41 AM »
Charles will remember my car I think in this area.
My restorer felt that the headlight doors fit like Ford did them originally.
I don't feel this way but I haven't as of yet tried to fix my left side door.
Weird thing is there is a repro on the right side and it fits perfect and lines up well with the hood.
I'm actually thinking about getting a repro for the right side and try it and if it fits well I'll have it painted and put it on
I also believe that MOST cars came off the line better than MOST restored cars do.
FYI Guys: MY fenders are "Ford Tooling" and it turns out that the repro headlight door fits perfect on the right side while the original Ford door on the left side doesn't
Not everyone has the abilities or wants to get and use original sheet metal, I am perfectly satisfied with my Ford Tooling fenders and hood, but used NOS (from the early 70s-red primer) full quarters....
Offline 66RavenGTCoupeAgain
« Reply #18 on: August 23, 2016, 04:31:26 AM »
Hey Guys,
Doing a non concourse restoration on my wife's 65 and found that the headlight doors are a fraction of an inch short in the internal triangular face that is seen at the inner top once the hood is open. This area is also what aligns with the inner fold of the top of the fender when you look down on the fender, hood and headlight door. I'm thinking of aluminium welding a plate on to the headlight door to increase the thickness. Will this work?
« Last Edit: August 23, 2016, 04:37:38 AM by 66RavenGTCoupeAgain »
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Offline rodster
« Reply #19 on: August 23, 2016, 10:24:24 AM »
I'm no expert but sounds like a great idea!
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #20 on: August 23, 2016, 11:55:41 AM »
Are all the parts Ford OEM?  I would look for another headlight door.
Offline JKWilson
« Reply #21 on: August 23, 2016, 06:45:54 PM »
I'm not 100% sure here but since the headlight door is cast potmetal I don't think you can weld aluminum to it. I could be wrong. I concur with Charles, look for another (several!).
« Reply #22 on: August 23, 2016, 08:47:04 PM »
I just measured my relatively untouched Oct 65 San Jose Fastback and it has the same gap as yours, about 3/32 inch. Your call -
« Reply #23 on: August 23, 2016, 11:30:26 PM »
Here's a Feb '65 San Jose car, all original assembly line sheet metal.
Offline sanluis09
« Reply #24 on: February 17, 2021, 03:03:29 AM »
Hi Gary, it?s been a while of this post, but I wonder how did you solved your allignment issues?
Thank you
Luis
1965 WW Hardtop, 289-2V, 3-speed manual transmission. Unrestored. Assembled in Mexico on the time frame of: Oct 64-Feb 65.
« Reply #25 on: February 21, 2021, 07:55:32 PM »
I ended up gluing the aluminum piece in with a special two part glue used in the automotive industry given to me by my panel beater. I was then able to slightly file and sand it to give me what I wanted. Very happy with the result.
Offline petersixtfive
« Reply #26 on: February 22, 2021, 04:46:27 AM »
Dan
Can you post a photo or 2 of the piece you added
Cheers
Peter
