Author Topic: Courtesy Lights Under Dash  (Read 2905 times)
Offline Dads Boss
« on: October 29, 2012, 02:10:14 PM »
Does anybody know what the bulb number is for these bulbs below. I have a 1970 and these are under the dash (courtesy lights)
Re: Courtesy Lights Under Dash
« Reply #1 on: October 29, 2012, 04:03:52 PM »
Try UL562, and get a couple of Mustang aftermarket catalogs. They usually have what you are looking for.
National Parts Depot - http://www.npdlink.com/
Virginia Classic Mustang - http://www.virginiaclassicmustang.com/
Offline svo2scj
Offline rayms69
« Reply #3 on: October 29, 2012, 11:59:57 PM »
i purchased some led lights similiar to the ones on the hipoparts site, if i am to use these i assume i must solder them in.Is that what any of you guys have done, i like the leds because less draw on the electrical system and they last longer.
10-26-1969 Dearborn 428 SCJ auto
« Reply #4 on: October 30, 2012, 12:57:58 AM »
Those should pop in similar to fuses except at the ends.
I've had four classic Mustangs (one 65, three 66's) since 1988. They don't get driven much but this year was the first I've had to replace a bulb, a headlight, in any of them. Incandescent bulbs are very resiliant. However, they get dim with age, sometimes get stuck in their sockets due to corrosion and the solder/lead base gets flat but that can be reformed. As to replacing bulbs with LED's, I prefer to keep my cars concours correct as best as I can, and $8 a bulb is not a good buy.
Offline rayms69
« Reply #5 on: October 30, 2012, 11:24:58 PM »
understand your rationale, i like the cool hue of the leds, dont plan on showing or really caring what others think. Just wondering if anyone had experience with this particular application of leds, i already purchased the bulbs and have originals that still light up. originals have the wire that wraps around and theleds dont, they dont want to stay in place like a fuse, a little solder might do the trick. For now i guess i will stay stock. My car is all original with exception of carpet, headliner, tires, brakes, gas, etc.....
Offline 1970 Snake
Under Dash Courtesy Lights
« Reply #6 on: December 29, 2020, 06:02:44 PM »
I have been looking and can not find a supplier for the somewhat unique under dash courtesy light bulbs. Can anyone please provide a possible source for these bulbs with the U shape wire end connections.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: Under Dash Courtesy Lights
« Reply #7 on: December 29, 2020, 07:23:27 PM »
Check your owners manual for correct bulb identification designation which will make it easier to search for .
« Last Edit: December 29, 2020, 07:25:15 PM by carlite65 »
Offline 1970 Snake
« Reply #9 on: December 29, 2020, 08:27:49 PM »
Thanks Bob and Brian, I did a different search and finally found the part number which is a GE 561 or Sylvania 561.
Yes the LED's are readily available but would like the original type bulbs which are much harder to find these days but now with the part number should make it a bit easier.
Thanks again.
Offline 67350#1242
« Reply #10 on: December 30, 2020, 09:44:28 PM »
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Offline 1970 Snake
« Reply #11 on: December 30, 2020, 11:26:25 PM »
Thanks, live in Canada, went to order some bulbs and they where very cheap, shipping was defined @ $210.00 USD. I have since located some Phillips 516 locally for $1.50 each.
