Author Topic: Sound deadener application  (Read 2789 times)
Offline nham3407
« on: October 22, 2012, 12:15:09 PM »
Looking for any possible pictures of sound deadener application on a 01/72, Dearborn, Mach 1.  Interested in all areas, trunk, wheel wells and firewall.  If I am missing any other areas please advise.
Thank you,
67 GT S-Code, San Jose, 06/67
72 Mach 1, Dearborn, 01/72
Re: Sound deadener application
« Reply #1 on: October 22, 2012, 04:35:55 PM »
I checked and sorry - haven't spent as much time on the 71-73s collecting details. With that said here is what I do have. Hope this helps
Rear wheelwells.  It appears the practice was different than earlier years with the worker typically stopping a long way from the outer lip
Splatter or overspray from the wheelwell application
Floor application of sound deadener for Grande and Mach. Like over years it appears that it was applied after much of the car was assembled (engine, trans, brake & fuel lines, rearend and such installed ) but no mufflers or driveline.
Trunk sound deadener is difficult to see  with the tri tone (Zonotone - (s?) over the top of everything
Front wheel wells were difficult to find pictures of. Like other years you have spray sealant along the rear seams then (after car was assembled - minus wheel and tires) sound deadener was typically applied to the majority of the surfaces and bottom of fender visible from below in the front wheelwell
First two pictures relate to a narrow application of spray on seam sealer prior to the sound deadener application to the front wheel well
No nice clear pictures of the firewall but pretty much like all later Dearborn cars. Heavy thick application of sealer around and over every opening, plug, screw, clip, electrical connection, bracket attaching to or coming through the firewall except fore the ground with and screw
« Last Edit: May 16, 2018, 06:17:48 PM by J_Speegle »
Offline nham3407
« Reply #2 on: October 22, 2012, 04:51:25 PM »
Thank you. Very helpfull.
Offline c9zx
« Reply #3 on: October 26, 2012, 10:54:49 AM »
Related information. This product worked well in those locations where brushed on seam sealer was used. http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=MSR4200_0006419404
Thanks, Chuck
1969 G code Cougar Eliminator
CSX 7031
« Reply #4 on: October 26, 2012, 03:22:56 PM »
Related information. This product worked well in those locations where brushed on seam sealer was used. ...........
Product is listed as being available in gray - is it also available in black?  Or is this a very dark gray - almost black?
Have to ask since I've not found it typically gray ;)
Offline c9zx
« Reply #5 on: October 26, 2012, 06:22:41 PM »
I've only seen it in medium grey with a slight greenish tint. Martin Senour Paints is the manufacturer. They may have it in other colors as a second part number is listed (4201) http://www.martinsenour-autopaint.com/media/pds/english/9514.pdf Neither spec sheet specifies color. Sorry couldn't be of more help. Chuck
Thanks, Chuck
CSX 7031
