Here's my shot at your list. ................................
batt tray S2
rear shock S8
rear shock S8
Charles have you seen original or NOS (old stock) with zinc washers?
All I can offer at this point is to share my work when it is presentable. From my perspective I think it would be really cool to have a database that someone can punch in some basics (model/year/plant/build date) and then have access to pictures/descriptions/part numbers/finishes...but that is the geak inside showing.
The only problem we're seeing in using the internet is that many get spoiled and immediately assume everything should be available at the click of the mouse with out acknowledgement or understanding the efforts (in time and money) it took to assemble the information. Believe, like most things in life, that we value what we work for and what is given does not often get the respect or value that it deserves. Just a thought and a comment
Getting back on topic, given the overwhelming success at the first run, I'll go back to the well again on a few more fasteners...
As we both mentioned before - don't assume any of our responses are 100% perfect until they are confirmed and backed up with real cars. - JMHO
Again some of this is going to take some time to confirm with some cars
1967 SJ
1. Strut rod cup washer (3A142)
2. Disc brake pad retaining bracket screws (small with tooth washer)
3. Upper control arm bolts - thru shock tower (perhaps originals are pressed in...mine were replaced and the bolts are not original)
Dark heat treated sheet
4. Parking brake bracket, on firewall just below the rubber tube that sticks through the firewall.
Semi-gloss black
5. Fender bracket C7ZB-16A005-6
Semi-gloss black
6. Fender mounting shims "U" shaped
Not often used - but if they used one it would have been zinc plated
7. Fuel line clips at gas tank, fairly complicated "S" shape
Draub Green oxide
As a note not all San Jose cars used these in 67 there were a number of different systems used to retain the fuel line and sending unit wire over the year.
8. Hood bumper bolt (exposed part below rubber top)
Originals look like cadium
9. Hood bumper jam nut
10. Hood bumper J-nut
11. Final one (for now...) more of a question - when I removed the accelerator assembly from the firewall, the three sheet metal screws .................... Comments on this?
If I recall correctly (could look through all the pictures but that's allot - maybe later) no washers But don't forget these would have had hard plastic (gray in color) covers over the ends (engine compartment end) once in stall
