Author Topic: 64.5 Dearborn Wheel Housing Paint Steps  (Read 3732 times)
Offline Alpha1946
« on: October 14, 2012, 09:29:02 PM »
Would the inside rear wheel housing be painted the same color as the undercarriage before applying the sound deadener?
« Last Edit: January 31, 2013, 10:01:18 PM by J_Speegle »
64.5 Wimbledon White Convertible
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Re: Wheel Housing Paint Steps
« Reply #1 on: October 15, 2012, 12:19:04 AM »
I'm uncertain (have not stripped through each layer of paint and coating on a car from Dearborn from that period)  on your particular period. In general (most years sound deadener was applied after the red oxide coat in the rear wheelwells. then would get some coating from the gray exterior filler primer coat. This all would then be covered by body color (the vast majority of the surface in the rear wheelwell and exposed frame rail in the opening.
So the primer over or under the sound deadener is not so visible on the finished product
Offline Alpha1946
« Reply #2 on: October 15, 2012, 09:03:49 PM »
Thanks for the reply Jeff
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Offline lscman
« Reply #3 on: January 24, 2013, 04:01:36 PM »
Jeff,are you saying that under the early car the underside was red oxide and the body was gray sealer?
« Reply #4 on: January 24, 2013, 07:18:11 PM »
Depends - what year (month) and plant are you asking about. Makes all the difference ;)
Offline lscman
« Reply #5 on: January 31, 2013, 10:10:11 AM »
Dearborn 64.5 Mustang built around July/Aug.?
« Reply #6 on: January 31, 2013, 11:06:04 PM »
Never had one to strip down to the metal (to determine if sound deadener is over or under primer). But the final results are the same as the other plants - exterior color
Re: 64.5 Dearborn Wheel Housing Paint Steps
« Reply #7 on: January 31, 2013, 11:08:21 PM »
A lot of times, I have seen sound deadener applied directly to bare metal.  Probably one of the reasons the cars had such bad rust problems in wet/salty environments.
« Reply #8 on: January 31, 2013, 11:27:49 PM »
There was a period of time where that was the practice at San Jose (early) then they changed later in 65 production to primer first.
Offline DM_1964
« Reply #9 on: February 01, 2013, 01:20:09 AM »
Interesting topic, I stripped back the sound deadener many moons ago on my early 64.5 (march), I still may have a little bit to take off tucked up right under the lip so I'll pay attention to see if any I can make out what went on when, this project has started and stalled a number of times over the last 15 years, I'm trying to get it up and running again...
Regards,
Dom
