Author Topic: 70 Steering Column = Paint or Natural  (Read 2166 times)
Offline sas_302
« on: October 07, 2012, 10:36:23 PM »
First post.  Searched the site and could not find an answer.
Is the end of the steering column including the coupler end just before the rag joint painted black, cast, or natural?  1970 if it makes a difference.
Scott
« Last Edit: October 08, 2012, 08:47:52 PM by J_Speegle »
Re: Steering Column = Paint or Natural
« Reply #1 on: October 08, 2012, 08:23:40 PM »
The end of the shaft is a formed steel (bare) shaft
« Last Edit: October 08, 2012, 08:51:49 PM by J_Speegle »
Offline sas_302
Re: 70 Steering Column = Paint or Natural
« Reply #2 on: October 08, 2012, 09:42:09 PM »
Thanks Jeff.  So clean it up and a little Boeshield it is.
What about the reverse lockout and the next approx 1-1/2" above it?  From your picture it looks bare as well.
Scott
« Reply #3 on: October 08, 2012, 10:31:18 PM »
I usually apply some of the heat treating (Gun bluing) to the bare steel them work it with a little steel wool to knock down the bright look you can get some times with freshly cleaned bare steel. Don't want it to stand out just blend in with all the different tones and finishes ;)
Scott
Yes believe the mech is just bare also
Offline sas_302
« Reply #4 on: October 08, 2012, 10:52:47 PM »
Excellent.  Thanks Jeff.  The Gun Blue is a great suggestion.
Scott
« Reply #5 on: October 08, 2012, 11:55:03 PM »
Just lightly - you don't want the dark heat treated look.   Sometimes I simply apply it with a clump of steel wool and work it in
