Well then lefts look at it this way. From what time period are the center links? If factory markings we should be able to find others from the same time period to support the idea
Don't think we see yellow used until later in the 60's on this application but we'll see
While we're discussing the center link in the picture - does that center link look bent to anyone else???
Jeff, the power steering centerlink, control valve, idler arm, pitman arm, tie rod ends
are all unique to 65/66 6 cyl cars, none of it interchanges with 65/66 V8.
It is a strange animal with the bend in the centerlink and the bolt on section that threads
onto the control valve. It's rare, not many 6 cyl cars had power steering in 65/66
The one I had was marked in the same area in a similar way, don't recall what colors were
used so that may vary as has been discussed before.
