Author Topic: 67 Mustang seat belt light  (Read 2466 times)
Offline 67foxgt390
  • Long time Mustanger
« on: September 25, 2012, 03:24:51 AM »
  Hi I have recently acquired an original under dash seat belt light for my 67. It was loose with no instructions. Does any one know where it should be mounted? The only one I saw in a car is right where the fog light switch is on my GT. Also  where does it wire into,It did come with the wires. Thanks!!
Re: 67 Mustang seat belt light
« Reply #1 on: September 25, 2012, 08:48:24 AM »
It usually mounts on the bottom edge of the dash, under the ignition switch.  The harness just plugs into an accessory plug that is powered on when the ignition is on.  Look for a 3-female yellow connector behind the instrument cluster or similar.
« Reply #2 on: September 25, 2012, 09:18:46 AM »
Charles you are thinking of the 68 harness with the yellow accessory plug. The 67 went on the main lug on the back of the ignition switch. :)
« Reply #3 on: September 25, 2012, 09:22:44 AM »
I was thinking 66, but thought I remembered seeing the same on 67.
« Reply #4 on: September 25, 2012, 05:16:55 PM »
I do not know about 66 but the 67 has an eyelet end and the 68 has the bullet end for the yellow plug. I bet Midlife know all about it!
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #5 on: September 25, 2012, 06:46:05 PM »
The 67 Ring Tab connects to the Accessory post on ignition switch. The 'L' shaped plug connects to the Relay. Lets see if my pictures will upload here. On this car the Light is mounted directly below the Ash Tray. In the second photo you can see the fusible link wire running back up the the ignition switch.
« Reply #6 on: September 25, 2012, 10:03:05 PM »
That is correct: it uses the ignition post.
The 67 A/C also uses power from a metal adapter to the ignition switch post (not for power, though), whereas the 68 uses the circuit breaker located on the fuse box sheet metal frame.
