I'm in the process of re-upholstering the front seats on my '67 Convertible, and noticed that there are 17 really thin wires (each about a foot long and spaced about an inch apart) woven into the burlap that goes between the bottom seat frame and the seat foam. There are similar wires woven into the burlap on the seat backs as well...
What do you guys usually use when replacing these wires?
I was simply going to try reusing these, but mine are so rusted that they keep breaking as I try to remove them...
The wires are made from 0.035in dia hard drawn steel cut to about 13 1/2 inch long for the seat base, the backs are 17 1/4 inches long. It is sometimes identified as piano wire. I got mine at a local arts and crafts store. Be careful as they also stock soft drawn, but soft drawn will work. You might check with Granger
http://www.grainger.com/Grainger/wwg/start.shtml .
Weaving the wires is a major task. There are several types of end terminations to retain the wires. I "terminated" the first wire end into a 270 degree loop about 1/8 inch dia, wove it and taped the loop end into place. I made the same loop at the other end after weaving. When I was done, I crimped a 1 inch wide strip of white cloth 20 inches long wadded up on the width into each wire end. I've also used a rolled up strip of burlap about the same dimensions. The finished wire, loop to loop, should be about 12 inches long, 16 inches for the backs. The ends are on the inside of the seat, as in up. Use a line drawn with white chalk to indicate where to weave the wires up and down, 6 downs and 6 ups, for about 12 inches, about 7/8 inches apart. This style burlap was used on a March 66 standard interior built in San Jose. The seat subassembly had a Los Angeles address.
Another type of termination uses a 14 inch long wire looped into a 1/2 dia loop 270 degrees for a finished length of 12 inches. Then a 1 inch flap of burlap is folded over the ends, then back with everything held in place by large 1/4 inch apart stiches with heavy white thread. This was on the seat base. I don't know the years or plant on this style.
I used 4 hours labor each seat section (8 hrs per seat) when I quoted this step so figure that into your task.
