Author Topic: Odd date casting on diff carrier  (Read 2413 times)
Offline Oz390
« on: September 12, 2012, 05:39:52 AM »
May '68 car, pinion support casting is 8E3, which is in line with the car... carrier is 8O27, misshaped C or Q for March?
8R03S : 76A I 2A 15M 72 5 U
Offline TLea
Re: Odd date casting on diff carrier
« Reply #1 on: September 12, 2012, 08:52:58 AM »
its in front of you but from here looks like C. No Q used
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #2 on: September 12, 2012, 12:56:31 PM »
I agree with Tim. It looks like a C. I have never seen anything past an M (December) in that date code format. It would revert back to an A for January of the next year.
« Reply #3 on: September 12, 2012, 04:49:02 PM »
My vote is 8C27.  Don't recall seeing an 'O' ever used for a date code.
« Reply #4 on: September 12, 2012, 10:02:24 PM »
At least not for the month code. Year and dates - plenty of "O"'s
« Reply #5 on: September 12, 2012, 10:29:42 PM »
That's the difference between 'O' and '0'... check your keyboard!   :o ;D
« Reply #6 on: September 12, 2012, 10:37:12 PM »
So its Cheeri0s not CheeriOs???   :P
« Reply #7 on: September 12, 2012, 10:59:51 PM »
Cheeri0s - Cheeri-zero-s !!
CheeriOs - Cheeri-OHHHH-s!!
Offline Oz390
« Reply #8 on: September 12, 2012, 11:37:10 PM »
Yeah, the flash gives it a different look than natural light... I guess the "C" used about a 0.148 mm gap between the open ends!  Some sites note the use of a Q, but never seen it...  I'll guess it sat for two months for some reason, fell off the truck or in a back corner....  ???
« Reply #9 on: September 13, 2012, 10:33:56 AM »
Typical 'Q' usage for dating has been for second year runs on warranty tags of a model year.  For instance, Mustang production starting in March '64, but being a 1965 model year... when the normal March '65 rolled around and they were still making '65 models, then Q had to be used.  Think there is a chart in the shop manual that shows the month codes as they apply to warranty tags (VIN plates.)
