Author Topic: 69/70 Backup Lights  (Read 3397 times)
Offline 69RavenConv
  • Owner since '74
69/70 Backup Lights
« on: September 07, 2012, 04:23:02 PM »
Aside from the evolution of the lenses, which is fairly well documented, were the 1969 and 1970 backup light housings basically identical? And is the 1142 bulb correct for both (which implies neither year was designed to take an1156 bulb)? There seems to be a lot of contradictory information on the web, even among vendors, and it's got me confused.
Phil
'69 Convertible - Dearborn June 4, 1969 - Raven Black & Red - 302-2V
Re: 69/70 Backup Lights
« Reply #1 on: September 07, 2012, 10:38:21 PM »
According to the ' 1969 Car Shop Manual ' chart on pg. 15-06-15;  Mustangs use the 1142 bulb.  All the other car lines Montego, Falcon, Fairlane and Cougar  take the 1156.  Brian
Offline 69RavenConv
  • Owner since '74
« Reply #2 on: September 08, 2012, 12:00:56 AM »
Thanks for your reply Brian. I'm aware that some vehicles used the 1142 bulb and others used the 1156; I'm interested in the difference (if any) between the 1969 and 1970 Mustangs. It's unclear (at least to me) whether or not they were identical.
Phil
Offline 7Lscjracer
« Reply #3 on: September 08, 2012, 01:17:55 AM »
No difference other than lenses.
Differences between assembly line and service part wiring pigtail though.
Thicker wiring on assembly line type with part number marked in white on the wire, unlike slightly thinner service type with part number on a tag.
I don't know if the thicker wiring is heavier gauge or just thicker jacket than the service type.
I've seen NOS service sets go for as high as $600 on ePay, and I just wonder why?
Keep the factory ones.
Bought May '81, sold Sept '20
Offline 69RavenConv
  • Owner since '74
« Reply #4 on: September 10, 2012, 10:39:48 AM »
Thanks, that makes sense. I know the 69's took the 1142 but I've not been up close and personal with an original 1970 housing.
Phil
Offline craig429
« Reply #5 on: September 10, 2012, 02:17:34 PM »
If NOS backup lights that have wiring without the part numbers stamped on the wires and with the part number tag are used on a concours trailered car, would points be expected to be deducted?
1969 Mustang Mach1 390
« Reply #6 on: September 10, 2012, 05:57:54 PM »
I would expect the answer would be yes since they do not look like the originals.
Now the details ;)
Since Concours trailered rules state that  judges should not look for engineering numbers ( Judges are not to deduct for the lack of them)  if the owner simply removed the paper/plastic tag then there should be no deduction.
Hope I explained that clearly
Offline craig429
« Reply #7 on: September 10, 2012, 06:10:04 PM »
Thank you Jeff,
You answered my second question, I will remove the tag. (As far as the judges would know, the printed engineering numbers worn off the wires during cleaning ;))
« Reply #8 on: September 10, 2012, 08:43:48 PM »
...........As far as the judges would know, the printed engineering numbers worn off the wires during cleaning ;))
Well - as mentioned - the judges should not be looking for the number in that class. Of course many would keep looking for a set of original wires and simply transfer them (steps spelled out in a certain 69 Shelby thread)  to the other housings ;)
