Author Topic: NOS parts for sale  (Read 6266 times)
NOS parts for sale
« on: January 10, 2010, 12:50:03 AM »
C7OZ-13A805-E   2   Deluxe steering wheel horn ring, both have C5   $150.00 each
C8ZZ-16A550-A   1   Pair of accessory mud flaps   $250.00 /pr.
C5ZZ-13734-A   3   Console lens   $25.00 each
C7OZ-16098-A   4   GTA fender emblems   $100.00 /pr.
D1AZ-3B584-A   1   P/S pump seal and gasket kit   $45.00
C3OZ-16228-B   4   289 fender emblems   $50.00 each
C5ZZ-15510-A   1   Box of 5 parking or backup lens gaskets   $20.00 for box
C5ZZ-7A624-B   1   Clutch pedal pad, with indent   $75.00
C5ZZ-2457-G   1   Brake pedal pad for manual trans, with indent   $50.00
C5ZZ-5C299-A   2   GT exhaust trumpet bezels   $100.00 /pr.
C5OZ-6243505-B   2   Trunk lock kit   $75.00 each
C6ZZ-8221-A   1   Grill molding center cover   $50.00
C7ZZ-6522811-C   1   LH lower door hinge, '68 style   $100.00
C5ZZ-6522800-B   1   RH upper door hinge   $50.00
C7AZ-16606-A   1   F hood letter   $30.00
C7AZ-16606-B   1   O hood letter   $30.00
C7AZ-16606-C   1   R hood letter   $30.00
C7AZ-16606-D   1   D hood letter   $30.00
D1ZZ-6540282-A-G 1   Set of MUSTANG stick on letters   $100.00 for set
C4DZ-6222404-A   1   65-66 and 69-70 Door handle, FoMoCo box   $150.00
C4DZ-6222405-A   1   65-66 and 69-70 Door handle   $150.00
C4DZ-6222454-A   2   65-66 and 69-70 Door handle push button kit, FoMoCo boxes   $75.00 each
C5OZ-13341-B   1   Turn signal switch   $150.00
C5ZZ-6524100-AFE   6   65-66 Std. interior door arm rests, white   $40.00 each
C4AF-11450-A   2   Starter solenoid, FoMoCo and REPCO on top, no boxes   $200.00 each
377901-S   8   Rubber seat nut access hole plugs   $50.00 for set
C5ZZ-2A635-E   2   Rear parking brake cables, '65 only   $125.00 each
C5ZZ-7652806-B   2   Convertible top tension cable, 65-68   $50.00 each
C5ZZ-13434-B   1   Tail light housing   $150.00
C5ZZ-17A750-A   2   Rear bumper to body brackets, zinc inserts   $100.00 /pr.
C5ZZ-3590-A   2   V8 pitman arm   $75.00 each
C3DZ-3047-A   3   Upper control arm shaft kits, with grease fittings   $75.00 each
      2   NOS 65-66 radio knobs, outer knobs   $50.00 /pr.
C5ZZ-2A602-A   1   65 parking brake equalizer bracket   $50.00
C3DZ-3020-A   2   Front coil spring cover rubber bumpers 65-68   $50.00 /pr.
C4DZ-16707-A   1   Hood latch support, '8  1' date, FoMoCo label   $50.00
C2OZ-6243200-B   1   Trunk latch, 65-66   $250.00
COTZ-13A024-A   1   Dimmer switch, flat top   $50.00
COMB-6443720-C   1   Trunk gasket, coupe/convertible only, original style material   $250.00
C5AZ-13480-B1   1   Brake light switch, FoMoCo with C5GB-13480-B stamping   $50.00
C3AZ-14413-B   1   NOS glovebox light assy. 65-68, small push pin, green wire   $75.00
5TMZ      1   NOS FoMoCo AM radio, Motorola, starts with '6'   $500.00
C4DZ-18578-A1   1   Early style heater fan switch with off in middle position   $50.00
C5ZZ-2282-D   1   65-66 Rear brake hose for dual exhaust, perfect plating, single crimp   $350.00
C3SZ-10316-B   1   Voltage regulator, D2TF motorcraft cover, can be swapped for a different cover, has          correct base for 65 and up   $200.00
C4ZA-18808-A   1   NOS dash speaker for 65-66, Bendix, FoMoCo ink stamp   $150.00
      1   Used 9" ring and pinion, 3.25 ratio, OEM Ford, very nice   $100.00
      1   Pr. of 65-66 hi-po exhaust manifolds, original with '65 dates   $500.00
      1   Black NOS '65 dash pad   $350.00
« Last Edit: January 10, 2010, 11:01:46 PM by caspian65 »
Offline outlawincorporated
  • Kangaroo Herder
Re: NOS parts for sale
« Reply #1 on: January 10, 2010, 09:24:07 PM »
CHARLES.
consider me the buyer of the;
will send you a follow up email.
regards.
PHILL  BERESFORD.
MELBOURNE.
AUSTRALia.
