Author Topic: looking for photos of coupe w vinyl top drip rails  (Read 5017 times)
Offline William-Fischer
« on: August 16, 2012, 09:00:13 PM »
I'm poetry sure there are pieces missing from my drip rails. The to was caulked at the edges and the appear to be holes for some kind of fasteners on the under side. There is metal trim on three outermost edge.
Can anyone show me what this is supposed to look like? I'm hunting for the pieces but am not 100% clear on what exactly I'm looking for.
Year:    6    1966 (April 28)
Plant:    F    Dearborn, MI
Body Series:    07    2 Door Hardtop
Engine:    C    289 2v V8
Body:    65B    2 Door HardtopColor:    M    Wimbledon White
Trim:    67    Lt. Aqua & White Crinkle Vinyl, Pony Interior
D.S.O:    65 OKC
Axle:    6   2.80:1, Conventional
Trans:    6    C4 Automatic
Re: looking for photos of coupe w vinyl top drip rails
« Reply #1 on: August 16, 2012, 09:37:16 PM »
There was an aluminum strip held in with pop rivets, inserted from the underside of the drip rail.  Then the area was caulked over.
« Reply #2 on: August 16, 2012, 11:18:30 PM »
So the caulk is correct? it's just so ugly....
Engine:    C    289 2v V8
D.S.O:    65 OKC
« Reply #3 on: August 16, 2012, 11:35:55 PM »
Yes, the caulk is correct.
Offline racerjmm33
« Reply #4 on: August 17, 2012, 12:53:00 AM »
Would pics of a very early 64.5 coupe help? I have an untouched one that has the pop rivets and caulk in place. Still has the original carpet that ends at the inner rockers, etc..
Will get some close ups of the drip rail tomorrow.
« Reply #5 on: August 17, 2012, 07:50:41 AM »
That would be a great help!
Engine:    C    289 2v V8
D.S.O:    65 OKC
Offline racerjmm33
« Reply #6 on: August 17, 2012, 03:31:51 PM »
Not great pics, car is stashed away, poor lighting...
Offline sparky65
« Reply #7 on: August 17, 2012, 08:12:38 PM »
Yep, my 67 had the caulk as well.  Now that you reminded me I need to put it back in.  What kind of caulk did they use, or better yet what should I use now?  I was going to use the stuff I installed the windshield with until I realized that it stays pretty sticky especially when it gets warm.
Steve
2009 Black GT Coupe
« Reply #8 on: August 17, 2012, 08:22:58 PM »
That helps tremendously. Is the bar on the underside simply a piece of metal molded to the shape of the rail then painted body color and riveted? Do the rivets go through the edge of the  top with the caulk being applied last? What kind of caulk should be used to reseal this? a
Engine:    C    289 2v V8
D.S.O:    65 OKC
« Reply #9 on: August 17, 2012, 09:03:19 PM »
There is no bar on the underside.  The vinyl top is installed and then the retainer bar placed in the gully of the drip rail.  The bar goes over the vinyl top material to hold it in place.  Rivets come from underneath to secure the bar in place.  Then a thick layer of silicone sealer is used to cover over the bar since it would look unsightly with rivet ends sticking up through it.  The rivet heads showing underneath were typically touched up with some color.  Although, I don't know if it was paint.  The examples I have seen almost look something like a paint pen or maybe even felt-tip marker.  The color is transparent, just enough to keep the heads from being too noticeable.
« Reply #10 on: August 18, 2012, 12:22:23 PM »
This is making sense now.
Does it matter how thick the bar on top is? Wondering if we'd have an easier time fabricating one than locating one. Since the bar is to be covered I'm not concerned with appearance.  Is there a ” correct” sealant for this?
Engine:    C    289 2v V8
D.S.O:    65 OKC
Offline mgmradio
« Reply #11 on: August 18, 2012, 05:49:21 PM »
From what I have seen on original tops including mine , the rivet heads were painte body color.
« Reply #12 on: August 20, 2012, 03:12:28 PM »
How many rivets should there be? My rails have 18 holes on each side but npd shows a complete set as only having 6.
Engine:    C    289 2v V8
D.S.O:    65 OKC
« Reply #13 on: August 20, 2012, 08:45:47 PM »
18 per side does seem like a lot.  Mike might be able to look at his '65 coupe with original top and let you know how many his has.
