Author Topic: 66 build sheet- where to get mine?  (Read 3015 times)
Offline William-Fischer
« on: August 15, 2012, 04:16:30 PM »
As I understand it build sheets are a good reference for doing things factory correct. I also understand the records for this year were long ago destroyed. How can I get my hands on this?
Year:    6    1966 (April 28)
Plant:    F    Dearborn, MI
Body Series:    07    2 Door Hardtop
Engine:    C    289 2v V8
Body:    65B    2 Door HardtopColor:    M    Wimbledon White
Trim:    67    Lt. Aqua & White Crinkle Vinyl, Pony Interior
D.S.O:    65 OKC
Axle:    6   2.80:1, Conventional
Trans:    6    C4 Automatic
Offline Pete Bush
Re: 66 build sheet- where to get mine?
« Reply #1 on: August 15, 2012, 05:12:58 PM »
Metuchen build sheets are the easiest to find. Not sure where your car was built.
Typical places to find them are folded and tapped to the wiring harness behind the instrument cluster. Other places include: under carpeting and headliners, behind door panels, and under seats. Don't be discouraged if you don't find any. They weren't always stashed in the cars.
You can find allot of my research at the following thread:
http://www.concoursmustang.com/forum/index.php?topic=3925.0
Would love a copy to add to my collection if you find it. I've got about 30 now. And every one helps a little in the decoding process.
Pete
« Reply #2 on: August 15, 2012, 07:52:47 PM »
Thanks for the feedback. If I find it I'll be sure to give you a copy. I knows where to look when I take things apart.
The car was built in Dearborn, late April if that helps at all.
Engine:    C    289 2v V8
D.S.O:    65 OKC
« Reply #3 on: August 15, 2012, 09:10:20 PM »
Unlike the later buildsheets the earlier versions are somewhat limited on their information and you'll find it a little more difficult to understand due to more coding being used during that period
Just allot of hunting. Just don' be disappointed if you don't find one
Good luck
« Reply #4 on: August 15, 2012, 10:35:40 PM »
If you haven't already, search/google, ' Mustang decoder '  This site will give you the info contained in your Vin. # and the door data plate.   Brian
« Reply #5 on: August 16, 2012, 08:51:18 PM »
Thanks for the tip, Brian.
I did that when researching the car prior to purchase earlier this year. Based on the  plate the car is very choose to original wick is why ended up deciding to go that route rather than resto mod.
Engine:    C    289 2v V8
D.S.O:    65 OKC
