Author Topic: Factory Jumper Wires  (Read 2248 times)
« on: August 14, 2012, 01:31:23 PM »
Starting to research these, many of them have part numbers imprinted. I think that these exist because:
  • The suppliers shorted the wiring in the harnesses
  • Wiring routed incorrectly during installation
Top wire is a jumper for the 1969-70 heater fan switch.
Second wire is a jumper for the brake light switch.
I have forgotten what the third jumper is for.
These jumper wires aren't real common. These have all come from Cougars 1967-73 Dearborn, and 1968-69 San Jose. I have no way of knowing exactly which specific car any of these came from. Just found in our tangle of wiring, removed from car over the passed 23 years.
Re: Factory Jumper Wires
« Reply #1 on: August 14, 2012, 07:58:57 PM »
You also have the engine loom adapter wire that was installed part way through 69 that corrected an issue.
The third one looks familiar - will have to think about that one. The other simple male/female extensions don't look familiar. Have seen the upper two examples a number of times
« Reply #2 on: August 14, 2012, 09:38:51 PM »
The jumper with yellow/black may be for power windows.  I've seen it before, but can't place it.  The power windows comes from the master list of wire colors/number/function.
I've seen the top two many times.  There's also a long jumper for the cigarette lighter for when the lighter is located in the back console area (69/70?).
« Reply #3 on: August 14, 2012, 10:42:33 PM »
Wiper motor for some reason is what I think is possible - but just another guess
The one with the female connection with the 90 degree/elbow?
« Reply #4 on: August 14, 2012, 11:30:45 PM »
The third one is a jumper for the vacuum release solenoid for a 68-69 tilt column. Marty
« Reply #5 on: August 15, 2012, 09:51:51 PM »
Correct.
