Author Topic: 68 Tie Rods  (Read 6334 times)
Offline Sunlitgold68
68 Tie Rods
« on: July 28, 2009, 12:14:25 AM »
Did 6 cylinders and small blocks use the same tie rods in 1968? Thanks
8T01C204XXX
Built May 14th, 1968
Re: 68 Tie Rods
« Reply #1 on: July 28, 2009, 12:35:51 AM »
Books (MPC, Moog & Raybestos) say yes.   No personal experience - but looks good
BTW - Welcome
« Last Edit: July 28, 2009, 12:44:22 AM by J_Speegle »
Re: 68 Tie Rods
« Reply #2 on: July 28, 2009, 12:36:29 AM »
All used the same in 67-69.
Offline T Lea
Re: 68 Tie Rods
« Reply #3 on: July 30, 2009, 07:53:19 PM »
This is nit picking but it is a concours forum. Although tie rod ends are the same 67-69 (except 69 w/ DO spindles) the boots had different engineering numbers on the rubber.
Re: 68 Tie Rods
« Reply #4 on: July 30, 2009, 09:03:29 PM »
Yep, that is right!
Re: 68 Tie Rods
« Reply #5 on: August 04, 2009, 01:22:21 PM »
Do all tie rods have the same shaped boot and the ring at the bottom?
8T01C204XXX
Re: 68 Tie Rods
« Reply #6 on: August 04, 2009, 01:55:41 PM »
The 67/8 style have the metal rings.  Not sure when the later style was introduced.  They are interchangeable from a function perspective.
Offline T Lea
Re: 68 Tie Rods
« Reply #7 on: August 05, 2009, 09:05:31 AM »
I think the ones without the ring came into play in 70. Scott Fuller makes a real nice 67-9 version w/o any engineering marks.(can't really see them once installed anyway)
Re: 68 Tie Rods
« Reply #8 on: August 05, 2009, 11:05:23 AM »
I bought an NOS one and it has a different looking boot, but does have the "B" stamping on the bottom. I guess I should get the ring style boot and take the other boot off?
8T01C204XXX
Re: 68 Tie Rods
« Reply #9 on: August 05, 2009, 04:09:22 PM »
The boots can be swapped with relative ease.
Re: 68 Tie Rods
« Reply #10 on: August 05, 2009, 07:45:47 PM »
That would be the 69's with the KKX or D0 spindles ;)
Re: 68 Tie Rods
« Reply #11 on: August 10, 2009, 11:14:57 AM »
Looked at my original inner tie rods and the part # on the boot is in large #'s. Much much different than the NOS ones you see. It is a C8 number.
How do you get the old boot off and put a new one on? It looks like the ring is attached pretty good to the base.
8T01C204XXX
Re: 68 Tie Rods
« Reply #12 on: August 10, 2009, 01:33:52 PM »
To remove the boot, tap the bottom metal edge with a piece of wood or use a chisel if you don't care about re-use.
Offline 68 S Code
Re: 68 Tie Rods
« Reply #13 on: October 05, 2010, 10:40:38 AM »
When you posted that 6 cyl and small blocks used the same tie rod in 68 does that mean that all 68's used the same tie rod 6 cyl,small and big block or did big blocks get a different tie rod?
Offline gtamustang
  • CPM
Re: 68 Tie Rods
« Reply #14 on: October 05, 2010, 03:42:15 PM »
All used the same regardless of engine size.
Regards,
Pete Morgan
