Author Topic: '68 Tilt column turn signal lever  (Read 1451 times)
Offline Oz390
« on: August 06, 2012, 06:20:38 AM »
I have a lever in "the collection" that has a nylon "bushing" near the base.  About 5/8" long x 5/16" diameter (guessing, I did not measure and its out in the shed)
Did the tilt columns use this to protect the lever from wearing against the tilt mechanism?  See only a one-size-fits-all repro, and hoping this is not unobtainium, or I guess one could machine up a nylon bush and press it on.... assuming it is correct.
8R03S : 76A I 2A 15M 72 5 U
Offline TLea
Re: '68 Tilt column turn signal lever
« Reply #1 on: August 06, 2012, 08:49:56 AM »
There was a discussion on these a while back. I dont remember what the conclusion was (I think they were non tilt) I've never seen one on a 68 tilt
« Reply #2 on: August 06, 2012, 09:40:55 AM »
Tim is right the bushing style will not work with the tilt version. Marty
Offline Oz390
« Reply #3 on: August 06, 2012, 10:42:05 PM »
Ok, does not sound original, but it did fit fine when I tried it... ;)
« Reply #4 on: August 07, 2012, 09:37:58 AM »
It fit on mine but when I pull it back to tilt the wheel the nylon bushing did not allow enough travel to release the paws. Marty
« Reply #5 on: August 07, 2012, 11:22:53 AM »
I think that the wand with the nylon bushing came out in 1970-71.
