Author Topic: One Last Bolt Question, Hopefully  (Read 1001 times)
Offline ChrisV289
« on: August 04, 2012, 11:49:09 AM »
So as I take things apart, I find some things right and some things I question...Below is a pic of a stud...Two of these were holding the power steering pump bracket along with the AC bracket to the front of the block below the valve cover...Are these correct?  I have only seen one other car built in San Jose with the same setup as mine around here in AZ and he had the same bolts/studs as well, but I want to make sure it is correct before I put everything back together
2009 V6 Mustang Coupe
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: One Last Bolt Question, Hopefully
« Reply #1 on: August 04, 2012, 01:33:02 PM »
Yep!  Correct.  Should be 3 I think and during SOME production periods, they have a lock washer under the nut.
66 Metuch Conv
Nightmist, Std Blu Int
