Author Topic: Thermostat housing  (Read 3498 times)
Offline ChrisV289
Thermostat housing
« on: August 03, 2012, 01:22:16 AM »
Is this the correct thermostat housing for a 65 SJ 289 FB (built 10/1964)?
2009 V6 Mustang Coupe
Re: Thermostat housing
« Reply #1 on: August 03, 2012, 02:06:29 AM »
It looks like a 68 version to me .
Offline Chris
« Reply #2 on: August 03, 2012, 07:53:13 AM »
Here's what's on my June 64 car.
-Chris
Offline ChrisV289
« Reply #3 on: August 03, 2012, 08:40:04 AM »
[/quote]
That's what I thought, that plug towards the top didn't look right...
Offline NEFaurora
« Reply #4 on: August 03, 2012, 09:20:57 AM »
The plug is used for an external Temp guage under the dash.. for anyone wondering... Just remove the plug and insert a standard temp sending unit...and voila..instant temp guage.. Summit sells nice 2" and 2 1/4" Autometer temp guages... or just use an old SW - Stewart Warner one from a swap meet..lol...
Tony K.
MCA#70001
« Reply #5 on: August 03, 2012, 09:27:32 AM »
That's not right.  This is a Ford t-stat housing for a later 289/302 with emissions control.
Offline 69SCJQ4.30
« Reply #6 on: August 03, 2012, 01:16:31 PM »
Tony K.
+1 for no temp sender, it was for a temp controlled vacuum switch with ports going to the intake, carb and vacuum advance
Offline mgmradio
« Reply #7 on: August 03, 2012, 02:39:22 PM »
Plus the temp sensor should be on the engine side of the thermostat.
« Reply #8 on: August 03, 2012, 05:00:39 PM »
Tony K.
The plug is used for the heat activated vacuum swich for the distributor advance curve  from the factory. It can be used as you say but most factory and after market aluminum intakes already have a place for a temp sender . I don't know why you would need two?
Offline rodster
« Reply #9 on: August 04, 2012, 11:06:45 AM »
Chris, if you are a 289 guy and don't have Bob Mannel's book on small block Fords you should. Lots of great info and pictures.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline ChrisV289
« Reply #10 on: August 04, 2012, 11:35:07 AM »
I do need to get that...maybe an early Christmas present to myself...
Offline rodster
« Reply #11 on: August 04, 2012, 11:39:11 AM »
Good idea.   ;)
You'll be -amazed- at the information in the book.
1984 SVO - 2A
