Author Topic: correct 1970 Mach 1 antenna?  (Read 4841 times)
Offline SCJSTU
« on: January 05, 2010, 07:55:10 PM »
ok, one more go round........what should the mast and base be for a 1970 model?
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
Offline rmaginnis
    • December 2010
Re: correct 1970 Mach 1 antenna?
« Reply #1 on: January 28, 2010, 02:27:24 AM »
The chrome base on mine is original and rectanglular with a 'tear drop' shaped insulator in its center.  The mast however is round and not tear drop.
Rick
« Last Edit: January 29, 2010, 09:53:24 PM by rmaginnis »
Rick Maginnis
April, '70 Dearborn Boss 302
0F02G18xxxx
Offline baflstangobx
« Reply #2 on: January 28, 2010, 10:19:26 AM »
In 30 years of Mustanging I have seen both on unrestored cars.  Since the antennas came in the trunks I am sure there were instances when the dealer prep guy could not find the factory antenna to install it or it was a teardrop mast with a rectangular base from the manufacturer.  The correct replacement is the C9ZZ-18813-A which carries a round mast on a rectangular base.  This is the basis to which all playing fields are leveled.  As in most cases with MCA, their statement in my opinion is to have all cars start from the same venue and not to declare that all cars were built this way.  If you are adamant about the teardrop mast then take the deduction.  Bill Weaver
Offline R code
« Reply #3 on: February 19, 2010, 06:38:21 AM »
Have a read of this thread been talked about :
http://www.428cobrajet.org/forum/index.php?topic=11916.0
Peter Manson
Brisbane, Australia.
9R02R
WT 7034 green Special paint.
priceless
  • Guest
« Reply #4 on: March 06, 2010, 12:44:07 PM »
Does this antenna apply for the 69 Mach1 also? I've heard of many variations of antennas for the 69/70 Mustang.  Also, where can you buy the doggone antennas? seems like the ones you buy from vendors are incorrect, and also seems like every vendors is different from one another.
 Please help, cause I'm having the same trouble too finding one.  I've heard Daniel Carpenter carries the correct antenna,,,,but, don't know for sure.
« Last Edit: March 06, 2010, 12:51:45 PM by priceless »
Offline SCJSTU
« Reply #5 on: March 06, 2010, 03:36:58 PM »
and another question.......
does the tear drop face to front or rear of car?
thanks,
st9mach1
  • Guest
« Reply #6 on: March 06, 2010, 04:32:44 PM »
 The "tear drop" points to the rear of the car.
 I have judged 69/70 concours Mustangs alot. But, no one seems to know who carries these antennas. I have heard Daniel Carpenter also. As priceless points out,,,many vendors show many variations.
« Last Edit: March 06, 2010, 04:34:16 PM by st9mach1 »
Offline Aussiemach
  • Silver Level Subscriber
« Reply #7 on: April 01, 2010, 12:36:02 PM »
what is this antenna? it's on a '69 vert
« Last Edit: April 01, 2010, 12:39:15 PM by Aussiemach »
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
Offline BillEBobb
« Reply #8 on: April 01, 2010, 04:43:58 PM »
That's a standard "parts house" replacement antenna that attaches to the "stub" after the mast has been broken off.  It's a generic piece that will work on any make/model.
