Author Topic: GT tip projection  (Read 3769 times)
Offline Jays66gt
GT tip projection
« on: July 31, 2012, 05:36:29 PM »
How far should the GT tips project out from the rear valance?  Is there a correct dimension?
1966 GT
6R07A105XXX
San Jose car delivered to Denver in September 1965.
Offline cobraboy
Re: GT tip projection
« Reply #1 on: July 31, 2012, 06:11:01 PM »
I was told that the small end of the cone where it is welded to the pipe should be directly over the bottom  fixing on the stainless steel hole trim in the valance.
I set mine up like this and they look right.
13th April 1965 Dearborn K GT on the other side of the pond.
« Reply #2 on: July 31, 2012, 08:23:17 PM »
Not sure but isn't the desired location notated in the assembly manual for the cars?
Thought I had seen that mentioned before
« Reply #3 on: July 31, 2012, 10:24:16 PM »
Assembly manual only shows a drawing (64.5-65 Chassis, Pg. 9-3.  As best as I can figure, the beginning of the major necking down to the 2 1/4" pipe from the GT exhaust tip is even with the bottom of the valence opening.
« Reply #4 on: July 31, 2012, 11:25:05 PM »
The 66 service manual show about the same, about where the transition from pipe to trumpet is located to the bottom of the ring. The only dimensions are the position of the trumpet, "concentric within 3/16inch".
Offline Jays66gt
« Reply #5 on: July 31, 2012, 11:30:58 PM »
Concentric within 3/16"?  Really?  How the heck do you pull that off?  The adjustment would have to be made at the rear most hanger right?  The trumpets have to be in alignment or they will not be level.
1966 GT
6R07A105XXX
« Reply #6 on: August 01, 2012, 12:01:41 AM »
Somewhere like this pic, maybe a little more in, but not much:
http://www.ct.early-mustang.com/charles/vert/Huntsville/Img_1228.jpg
« Last Edit: June 02, 2013, 01:56:59 AM by caspian65 »
Offline Jays66gt
« Reply #7 on: August 01, 2012, 01:07:01 PM »
Those tips look like they project out to the bumper.
1966 GT
6R07A105XXX
« Reply #8 on: August 01, 2012, 01:30:56 PM »
It's a deceptive dimension. Whatever extension length the trumpet is, it must be centered with a tolerence of 3/16 of an inch. That means if the "gap"is 1/2 inch, or 5/8 inch, or 3/4 inch, it must within 3/16 all the way around.
(Mentally picture a 4 inch diameter funnel centered in a 3 inch diameter pipe, now move it up or down.)
How you do that is moving the tip in and out and moving the brackets up and down (final adjustment with a 4 pound sledge hammer).
Offline rocket289k
« Reply #9 on: June 02, 2013, 12:29:43 AM »
http://www.early-mustang.com/charles/vert/Huntsville/Img_1228.jpg
Hi Charles - I tried the link you posted but it's broken.  Could you please repost or send me a PM.
Thanks!
Ron
« Reply #10 on: June 02, 2013, 01:57:14 AM »
Should work now....
Offline rocket289k
« Reply #11 on: June 02, 2013, 10:12:36 AM »
Should work now....
Still not working. It appears that the "early-mustang" domain is no longer active as the link directs me to a SEDO domain parking page.
« Last Edit: June 02, 2013, 10:14:10 AM by rocket289k »
« Reply #12 on: June 02, 2013, 10:55:51 AM »
works perfectly fine for me.
« Reply #13 on: June 02, 2013, 12:17:12 PM »
Don't use the link that you quoted in my reply, go back to my original post and use the link there.
Offline rocket289k
« Reply #14 on: June 02, 2013, 12:43:42 PM »
Hi Charles,
I didn't notice that you updated the link in your post.
Ron
