Author Topic: July '64 Dearborn details  (Read 6311 times)
« on: July 27, 2009, 10:32:02 PM »
If anyone has a June/July '64 Dearborn car, need info on the following:
-What type of firewall pad is installed, textured or dotted?
-Do the doors have the screw-on pads for the courtesy light switches?
Re: July '64 Dearborn details
« Reply #1 on: July 28, 2009, 03:17:40 AM »
Guessing that the dates would mean cars between approx 160000 and 210000?
If so here are a couple with the typical textured (no pattern like typical San Jose) pads
5F08K20878x.
5F07F21812x
Don't have any good angles showing the door plunger plates :(
Offline buckeyeresto
« Reply #2 on: July 28, 2009, 12:41:17 PM »
Charles,
Every 64 1/2 June / July car I have had has the textured typical dearborn pad.  On the Door Plates those were phased out when the door post design change was made for the post to have the dimple for the switch incorporated in the design.  I have seen cars built early july with the older door post on one side and the improved door post on the other side.  On my july 20th k vert the door post are the improved type and their is no plate on the original doors
nate
« Reply #3 on: July 28, 2009, 12:50:38 PM »
Thanks Nate, that helps a lot!
« Reply #4 on: July 28, 2009, 01:04:13 PM »
I will try rounding up some pictures of the flat door post and the improved door post.  I would say if the car had the improved door posts it wouldn't have the door plate
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #5 on: July 29, 2009, 07:38:44 PM »
My June 29 64 Dearborn coupe has the strinker plates and textured firewall pad.
« Last Edit: July 29, 2009, 10:57:11 PM by 5F09CNot4Sale »
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline Charles Potts
« Reply #6 on: July 29, 2009, 09:39:08 PM »
Charles,
Thanks for your help.  I actually remember removing my original firewall pad and it looked exactly like the pictures above!
I think the guy that stored my car and parts discarded the pad.
Hopefully someone has a nice textured firewall pad for sale.
Charles Potts
« Reply #7 on: July 29, 2009, 10:40:27 PM »
Well, we've got one question answered now.  Looks like the door switch pads can go either way.
« Reply #8 on: July 29, 2009, 10:50:17 PM »
Its like the arm rest bases... when were they phased out.  we know for a fact July 20th car has 64 arm rest bases and no striker plates.  question is whats before it any other dates of cars... we have a late june as well.  with both
« Reply #9 on: July 29, 2009, 10:52:48 PM »
Fun huh?  And let's not forget that's the scheduled date on the warranty plate!
