Author Topic: styled steel wheel restoration  (Read 9506 times)
« on: July 22, 2012, 07:17:17 PM »
Looking for hints on how to restore styled steel wheels.
I was thinking to do this:
1. Grind out rivets from wheel side
2. Punch out rivets and save for later
3. Get centers rechromed, followed by appropriate paint
4. Refinish wheels in black on epoxy primer (not power coated)
5. Refinish rivets (P&O or gun blue)
6. Insert rivets and weld from wheel side (for looks only)
7. Weld center to wheel along edges on back side, grind, and paint
This is assuming that nobody will want to install rivets for safety purposes, which may not be the case.
I'm interested on what has been done by others, and what mistakes to avoid.  I did a search on this site and did not see any threads. Thanks, John
Re: styled steel wheel restoration
« Reply #1 on: September 01, 2012, 09:37:39 AM »
So am I going out on a limb doing this?  Is this a dumb idea?  Or does everyone just order repros?
« Reply #2 on: September 01, 2012, 10:50:38 AM »
I've never done them.  Always either used repro or NOS when needed.
Think there are liability issues with the wheel re-riveting, not many places will do it these days.  Did you check in Hemming's for any places that offer wheel restoration?
« Reply #3 on: September 01, 2012, 12:05:29 PM »
Charles is correct, use repro or NOS. I have a set of 5 original Style Steel Wheels on my 66 Fastback in very good condition. I removed the remaining paint and re-painted them. My 65 has 4 original "all chrome" type Style Steel Wheels and I'm tempted to have them re-chromed but the chrome shop said that there was a strong possibility that corrosion would show after a period of time where the center was riveted to the outer section. I'm considering repro as the costs are about the same. For my 66 Hardtop driver I took some advice from someone even older than me and got a set of 67 repro wheels as I have a set of Cooper radials tires and the extra width (not much) would be better. This was about 10 years ago and they look and work fine.
Offline MyRed66GT
« Reply #4 on: September 29, 2012, 10:55:18 PM »
Just found a place that might be able to restore your SSW's for you. McWheels. 605 6th Avenue. Slater, Iowa 50244. 515-685-3397. curt.mckim162@gmail.com. Sounds like you are looking at about $140 per wheel. Of course not able to re-rivet, must weld.
« Reply #5 on: September 29, 2012, 11:39:47 PM »
Difficult to true the wheel before rivet /welding for DIY i have heard. The original wheel rim is slightly different compared to modern replacement DOT approved rims . The replacement centers are pretty much spot on. If you can't get the riveted look it is not worth restoring IMHO. Check specialty wheels they used to sell riveted replacement.
« Reply #6 on: September 30, 2012, 08:53:01 AM »
Thanks for the replies.  If I decide to go with a restoration I'll post the details and results.  John
Offline C5ZZKGT
  • Gold Level Subscriber
« Reply #7 on: February 11, 2013, 05:10:29 PM »
Any tips as to how you prepped and painted your SS wheels?
« Reply #8 on: February 11, 2013, 08:03:28 PM »
Have a local company that changes out centers and rims on a regular bases if you want to send that step out to professionals. Might be fun getting the rivets completely sealed. Good luck
« Reply #9 on: February 12, 2013, 12:22:15 AM »
I made paint masks from old unused IBM punch cards. The stiffness of the card was what I needed. It was trial and error but eventually I got a set of five (one for each open slot in the wheel), a roll of masking tape, a glass of wine and a good day to paint. It alsp helps if you've been building plastic model cars, planes and ships for a verrrry long time.
« Reply #10 on: July 15, 2014, 05:19:39 PM »
Going to bring up an old thread. I would preffer using my OE wheels if at all practical also.
Repops? That is the answer? Seriously, we cave in to repops because of why? ...the Rivets? Obviously Kelsey did a fine job and they lasted 50 years, all we want is to rechrome the centers and put them back! Seems easy enough if we are already riveting ball joints back in. Just my 2 cents worth
Richard
« Reply #11 on: July 15, 2014, 06:13:28 PM »
Richard
Because it isn't always practical  ;) . Tools needed and cost are not practical many times. Not a typical DIY job. True design wheels in CO is one company that can and will restore them . You will have to contact them for a price for disassembly of good usable cores,  rechrome of rim (If usable) ,  rechroming of center,  riveting together the trued assembly and final center detail. That is why a good repro is the answer for some.  I would also add a repro is a 1 800 number away which sometimes makes a difference.
« Reply #12 on: July 15, 2014, 07:14:02 PM »
I'm not there yet, but am committed to do this myself or possibly with "True Design Wheels" (thanks for the tip Bob) if the price to effort ratio is reasonable.  And I'll report back on the results.
Offline Toploader
« Reply #13 on: July 16, 2014, 04:46:46 PM »
+1. Wheel riveting: A critical factory process involving great safety concerns. Must control steel grades, tolerances, temperature, pressure rates, conduct (destructive) test procedures to ensure strength etc.
Appreciate your commitment though.
76A-Y-D2-13H-72-6-6
Offline 79mustangcobra
« Reply #14 on: July 16, 2014, 05:45:53 PM »
I agree.  Take care
1979 Mustang Cobra 5.0
2P Red and 1C Black
Stock never goes out of style
MCA #70281 -  79-93 MCA Concours Judge
Proverbs 3:5-6
