Author Topic: Water Pump / Timing Cover / AC / PS Bolts  (Read 1153 times)
Offline ChrisV289
« on: July 18, 2012, 01:19:27 AM »
So we know that the engine was partially together when it was painted.  My question is, if the car came with power steering and/or air conditioning, were those brackets (or pulleys) attached to the engine when it was painted or were they added later?  If they were added later, would the bolts that had to come off the water pump to attach the brackets be chipped in some way when they were removed?  Would they have been touched up later?  Are there any bolts that should not be painted?  Just something I am currently thinking about when planning on putting the front half of my motor back together.
2009 V6 Mustang Coupe
Re: Water Pump / Timing Cover / AC / PS Bolts
« Reply #1 on: July 18, 2012, 02:50:00 AM »
P/S and A/C brackets were not on the engine when painted . The bolts in the water pump would have been painted when the engine was painted. Yes it would be normal to see some chipping of paint where the bolts were taken out and reinstalled when the brackets were added. No Ford didn't go back in and touch up the bolts.
Offline ChrisV289
« Reply #2 on: July 18, 2012, 11:12:03 AM »
So at a MCA show, if there were chips present, would there be any point subtraction?
« Reply #3 on: July 18, 2012, 02:59:08 PM »
If the chips were consistent with a typical installation then no deductions IMHO. With that said it is up to the individual judge and his or hers understanding of the process.
