So next question, how should the starter be painted/restored? The top portion has some surface rust...what's the proper finish on this? Thanks
Brown paper gasket underneath the rear metal band, entire unit painted semi gloss black up to partialy painted nose (so as the retain good ground when bolted up.
An example to illustrate and help the discussion
To add to the picture and the information it offers the starters began being metal stamped with engineering numbers sometime in 67 . Before that they were ink stamped.
Good catch Bob - considering this is the 64-66 section of the site
