Author Topic: Mustang  (Read 4106 times)
meltdwn65GT
  • Guest
Mustang
« on: July 10, 2012, 01:59:11 AM »
« Last Edit: July 21, 2013, 08:53:15 PM by 5RFastback »
Offline 69SCJQ4.30
Re: Details to punch hole in fender for antenna
« Reply #1 on: July 10, 2012, 02:54:53 AM »
I don't think they used a punch cause they were installed at the dealerships after delivery!
Offline kutzoh
  • Gold Level Subscriber
« Reply #2 on: July 10, 2012, 07:03:44 AM »
Check here:
http://www.hammar.dyndns.org/options.htm
Scroll down, not quite half way, there's a template for radio antenna.
Greg
« Reply #3 on: July 10, 2012, 08:30:00 AM »
It wasn't a punch, it was 2 drill-bit sizes.  You can accomplish making the small hole relatively easy.  I have used a step drill-bit to do the larger one, you can buy them at Lowe's or Home Depot.  Heat can be a factor if you're doing this on a freshly painted fender, so be careful.  Also, cover over the fender and cowl so no hot bits/shards get on the paint.  They can leave little burn marks.
« Reply #4 on: July 10, 2012, 11:09:59 AM »
For the holes in my hood for the hood pins, I used a tool used in the electrical trade for making holes in electrical panels.
« Reply #5 on: July 10, 2012, 01:57:46 PM »
I have a set of knock-out punches.  My only concern would be the way the blade cuts, potentially twisting the metal.  On an OEM piece of sheet metal, probably not a problem, but I would hate to see what would happen with a foreign-made piece!
Offline jmlay
« Reply #6 on: July 17, 2012, 01:02:24 PM »
From the template it looks as if there is a 5/16 start hole & then it is cut with a saw not a larger drill. my original fender looks as if it was cut with a saw as well.
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Offline VikingNJ
« Reply #7 on: August 02, 2012, 02:56:37 PM »
Meltdown65GT,
To create a nice clean hole without sharp edges, you can get yourself a "GreenLee" punch. Verify hole size needed. The punch come in three pieces, top & bottom cutting punch and a bolt. Only need to drill hole for small bolt. Use a wrench is all you need. You will like the results. All machinist and tool makers know about this punch. Good luck
« Reply #8 on: August 02, 2012, 04:00:47 PM »
Meltdown65GT,
You need to be able to access both sides of the fender to use a Greenlee punch, one side for the die and the other for the punch. The die side is where the bolt is located. The hole will have a slight edge on the die side. You still need to drill a hole the antenna base "key" (although a Dremmel tool or rat tail file may work). The hole size is around one inch dia (I can't find my template) and e-bay has one for $39. CHECK DIAMETER BEFORE YOU BUY.
Offline kutzoh
« Reply #9 on: August 02, 2012, 04:57:57 PM »
Jim-
   I referenced the template in my post above, it's 1 1/8".
Greg
« Reply #10 on: August 02, 2012, 09:47:49 PM »
meltdwn65GT   Great info and link! Got the hole drilled today. Thanks
I did mine with a hole-saw bit and a variable speed drill motor.  Used a file to create the key-way.  Brian
