Author Topic: Decals and tags for 1972 Mach 1  (Read 1655 times)
Offline c9zx
« on: June 29, 2012, 03:49:00 PM »
I'll start with what is likely the dead horse but I did not find anything using the search function. Build date 03/16/72, Dearborn, should the "Caution Fan" decal be on the shroud? I've heard they started being installed at the factory around January 1972. This is just hearsay at this point.  The blue and white paper tag at radiator filler neck "you're protected......" should it be there? I can find no evidence of an air filter decal on the air cleaner of the 1972 351C Q code engine. Is this correct?
All help appreciated,
Chuck
Thanks, Chuck
1969 G code Cougar Eliminator
CSX 7031
Re: Decals and tags for 1972 Mach 1
« Reply #1 on: June 29, 2012, 09:09:57 PM »
Found these three examples in my data base - they do appear consistent. Hope this helps
2F02Q1735xx
2FO2Q1761xx
2F03Q215563
