Author Topic: Front Bumper to Valence Nut Insert  (Read 1411 times)
Offline drummingrocks
« on: June 13, 2012, 12:12:00 AM »
I'm installing a new bumper on my '69 Mach 1. It was built June 5th, 1969, at Metuchen.  I'm having trouble figuring out which way the nut insert installs into the front valence.  I've tried the Body Assembly manual, but I can't tell how the insert installs--should it be installed with the actual nut insert on the outside of the valence, or on the inside?  Which way is correct?
By drummingrocks at 2012-06-12
Offline rockhouse66
Re: Front Bumper to Valence Nut Insert
« Reply #1 on: June 13, 2012, 09:55:14 AM »
'66 GT FB
Offline BillEBobb
« Reply #2 on: June 13, 2012, 12:24:45 PM »
This photo shows the correct way:
« Reply #3 on: June 13, 2012, 01:07:36 PM »
Thank you, that helps a lot!
