Author Topic: 1969 Steering Column Lower Cover  (Read 3632 times)
Offline Stangman68
« on: June 06, 2012, 11:40:32 AM »
OK - Here's my question:  I have two lower cover's one with plastic tabs, and one with metal "spring" tabs.  One is C9ZB-6304459-B AND THE OTHER: C9ZB-63044F08-A.  Does anyone know the difference?  Is one the elusive "tilt column" cover??  Thanks.
Offline Brian Conway
Re: 1969 Steering Column Lower Cover
« Reply #1 on: June 06, 2012, 02:19:36 PM »
I have the C9ZB-6304459-B w/ plastic tabs.  69 Mach1 non-tilt.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #2 on: June 08, 2012, 12:33:20 AM »
I don't recall ever seeing one with plastic tabs. Mine have all had the Metal Spring Tabs on Tilt-Away or Fixed Column.
The Fixed Column Cover has 2 tabs coming off the sides of the end that mounts under the column collar flange.
The Tilt-Away Column Cover has that section 'Cut Away'.
Here is a photo of a Tilt-Away cover
Offline 69SCJQ4.30
« Reply #3 on: June 08, 2012, 04:33:41 AM »
I think he is actually referring to the plastic lower cover that is a finish piece not the wiring cover. Yes there are two different part number ones I have seen and I believe one of them uses additional aluminum spacers between the dash and the column mounting bracket. There are also two versions of the little textured rubber finish piece that goes in front of the instrument bezel and lower cover due to said additional spacers.
    • MagMustangs
« Reply #4 on: June 08, 2012, 01:08:09 PM »
Mmm, That explains a lot, LOL. Sorry.
I believe it is the Fastback that uses the Additional Spacers between Column Bracket and Dash, IIRC
« Reply #5 on: January 15, 2020, 06:02:54 PM »
Attempting to get clarity on this item.
The 1975 MPC calls out a 6504459 part for coupes and convertibles, and a 6304459 part for fastbacks.  These are both unique to 1969.
There are pictures of the plastic tab version here:  http://www.concoursmustang.com/forum/index.php?topic=21087.msg132519#msg132519  This part has is stated to be a 63 (fastback) part.  However, embossed in the plastic are BOTH the 63 and 65 part numbers.
The second picture is one with the metal tabs.  I have no other information about it, and forget where I ripped the picture from.  Hand written on the box is the 63 number.
Does anyone know which is which?
Thanks, John
« Reply #6 on: January 15, 2020, 08:01:42 PM »
Just to make the discussion and comparison easier and just in case those pictures disappear since they are not linked to the site gallery
Don't think I've got a picture to add in my collection and tossed all the broken ones I had
Just thinking out loud - it this a case of different suppliers or a running change?
Offline HDAshmore
« Reply #7 on: January 21, 2020, 01:28:31 PM »
Those are my pics if anymore are needed for this discussion I can take and post.
Dan
« Reply #8 on: March 15, 2020, 07:12:50 PM »
I was able to get my hands on about 10 more of these covers and have created the attached document.
Feedback on this would be appreciated.  Thanks
Offline Buzz489
« Reply #9 on: June 25, 2022, 09:13:08 PM »
On this subject of steering column covers.  Below the part number C9ZB-6504459-C there is a K1, K2, K3 or K4. Are there any differences in a K1, K2, K3, or K4?
« Reply #10 on: June 25, 2022, 11:15:15 PM »
Don't believe there is any difference between one marked K1 and the others. My guess would that identified the injection mold the part was made in so that any defects or issue they could narrow down to just one rather than search through all of them
