Author Topic: 64.5 mustang gas cap  (Read 3410 times)
Offline macdude67
« on: June 03, 2012, 09:06:24 PM »
Can someone tell me when they started to put the cap retaining cables on the 64.5/ 65 Mustang gas caps. I have a mid june of 1964 Mustang and I wondering if it does or does not supposed to have the cap with the cable retainer? Car came with a 66 cap so thats obviously not correct.
Re: 64.5 mustang gas cap
« Reply #1 on: June 03, 2012, 11:19:44 PM »
The fuel filler neck is unique for the non-bail gas cap.  If someone just switched the cap, maybe you still have the original filler neck?  The 64.5 filler neck has all oval holes for the screws.  The later filler neck has 1 circular hole and the rest oval.
Not sure when the switchover was to the retaining cable, but the old style caps were used at least until early June '64.
Offline kutzoh
  • Gold Level Subscriber
« Reply #2 on: June 03, 2012, 11:39:27 PM »
I've got a late June build date and have the early style fuel filler neck.
Greg
Offline macdude67
« Reply #3 on: June 04, 2012, 02:43:15 PM »
Thanks everyone. You were right someone put a 66 cap on it but left the original neck which has all oval holes.
Offline GrampsMan
« Reply #4 on: June 05, 2012, 11:46:54 PM »
My 64.5 convertible is a June 2 Dearborn build and has the cable on the gas cap. I've owned it since 1967 so it is original.
« Reply #5 on: June 06, 2012, 01:00:41 AM »
I wouldn't be so sure about that.  Seen lots of early June cars with no wire.
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #6 on: June 06, 2012, 02:28:58 AM »
I have a June 29 car with no wire.
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline Chris
« Reply #7 on: June 07, 2012, 11:12:35 PM »
Mine is a 19 June car with no wire.
« Reply #8 on: June 23, 2013, 08:55:47 PM »
Helping a friend with a 2nd week of July '64 scheduled build date.  Wondering if anyone has seen any July '64 cars with or without the gas cap retaining cable.  His has no retaining cable, but I believe the tail light panel might have been replaced.
Offline michaelvonlanthen
« Reply #9 on: November 22, 2017, 09:58:06 AM »
a bit late for Charles question.. but, my car has a no-wire cas cap. Car was build July 6.
Michael Vonlanthen
Switzerland
5F08D189*** - 76A   F   42   06G    75   1   6
Guardsman Blue Convertible with white interior, AT, PB, AC, console, Rally-Pac
Offline 196667Bob
« Reply #10 on: November 22, 2017, 11:19:58 AM »
Keeping the above in mind, just be aware of the attached Accessory.
Bob
MCA 04909
« Reply #11 on: November 22, 2017, 11:33:31 AM »
Bob
It doesn't say anything about replacing the filler neck, which as was mentioned earlier, would have only oval holes.  The bail wire filler neck has a single round hole.
Offline 196667Bob
« Reply #12 on: November 22, 2017, 12:22:41 PM »
Correct ; that is why I quoted your Reply about that. To me, this would be the "dead give-away".
Bob
MCA 04909
