Author Topic: Smog tube ID help??  (Read 1574 times)
Offline Andrew@MagMustangs
    • MagMustangs
Smog tube ID help??
« on: May 31, 2012, 01:05:59 AM »
Hoping someone can help me identify a smog tube manifold. I have 2 tubes that are similar except the check valve mounts on the opposite end. I know one tube is the FE big block RH tube, and I have one that when sitting next to the FE tube and the 4 nut-ferrule tubes are oriented the same direction it has the check valve mounted on the opposite end. Anyone know what this is correct for? Thanks for any help. Andrew
390-428 Tube: Top Photo
Unknown Tube: Bottom Photo
Re: Smog tube ID help??
« Reply #1 on: May 31, 2012, 06:38:48 PM »
1966-67 FE, such as Thunderbird and truck.
    • MagMustangs
« Reply #2 on: May 31, 2012, 10:59:13 PM »
Thanks Scott, I appreciate your response. I assume it's Not correct for 67 390 Mustang-Cougar?
The one in my lower photo is the same one WCCC has listed for 68-70 390/427/428 on the new site. Is the WCCC photo just a representative photo?
