Author Topic: '67 GT350 Headlight Bulbs and Inboard Bulbs  (Read 2803 times)
Offline ceswert
  • Silver Level Subscriber
« on: May 24, 2012, 11:11:26 AM »
Are the inboard headlight bulbs exactly the same as the regular headlight bulbs?
67' Shelby GT 350 nm blue/4sp/#0089
07' Shelby Super Snake 725hp/white/#0073
71' Mach 1 429cj grabber blue/4 sp./ac
Re: '67 GT350 Headlight Bulbs and Inboard Bulbs
« Reply #1 on: May 24, 2012, 12:17:02 PM »
They are two prong high beam only.
Offline ceswert
« Reply #2 on: May 25, 2012, 10:53:40 AM »
Thanks!
« Reply #3 on: April 13, 2018, 01:56:59 PM »
I've been going through the 67 Shelby section with more zeal of late and ran into this thread.
Some good research has been done on GE bulbs -- one of the most common Ford bulbs -- here:
http://www.chrysler300club.com/tech/headlamp/lamp1.html
Credit for this information should go to the Chrysler 300 club.
Of course they don't get into Ford script bulbs but I thought some of the GE identifying marks were important. Note that the GE bulbs in question here were during the early Mustang production time -- not before.
  • Prior to January 3, 1972 all Ford/GE bulbs were wide flute lens design
  • January 3, 1972 and on had the narrow or small flute design
  • Prior to January 3, 1972 the top of the bulb had a "1" for the 5¾ inch high beam lamp, "2" for the 5¾ inch low/high beam lamp
  • January 3, 1972 and on had "1C1" for the 5¾ inch high beam lamp, "2C1" for the 5¾ inch low/high beam lamp
I understand judges look for GE bulbs (and Tung Sol?) at minimum and Ford script (optional?) but do they also look for correct flutes and top of bulb markings?
I've been collecting bulbs and find that non-Ford vendors often give old bulbs away!
« Last Edit: April 13, 2018, 02:36:38 PM by Bossbill »
« Reply #4 on: April 13, 2018, 02:14:42 PM »
We look for Ford script and flutes. Both sides must match. BTW Westinghouse also was a supplier. They had a raised script that was kid of neat.
« Reply #5 on: April 13, 2018, 02:22:30 PM »
Might want to look at this related thread.  Search words "headlight flute"
http://www.concoursmustang.com/forum/index.php?topic=13239.msg81117#msg81117
Ford info seems to not match what the other source you sighted came up with if I'm reading the information correctly
« Reply #6 on: April 13, 2018, 02:40:41 PM »
Ok, I updated my post for the correct date -- and the TSB will reign supreme!
Wonder if that was a Mopar implemented date.
Thanks for judging update, ruppstang.
« Reply #7 on: April 13, 2018, 03:55:51 PM »
+1 Westinghouse was a supplier but I have not found one on a 65-67 Shelby.  I don't believe it was a very often used supplier to SJ plant if at all.
