Author Topic: Where Fog Light Switches Hard Wired From The Factory?  (Read 1221 times)
Offline MWM
« on: May 21, 2012, 11:24:42 AM »
Were the factory installed fog lights with the switch at the dash hard wired or plug in? I thought the latter, but recently a question came up. 1965 A code San Jose fastback.
Thank you!
Re: Where Fog Light Switches Hard Wired From The Factory?
« Reply #1 on: May 21, 2012, 03:45:23 PM »
The fog light switch plugs into a plug in the main wiring harness and there there are 2 wires for the breaker and then a feed wire that goes into the engine bay.
« Reply #2 on: May 21, 2012, 05:22:23 PM »
Thank you!
Actually a bit of both. The switch is hard wired via a six inch long three wire lead to a three pin conector that plugs into a special main under dash harness that includes the fog light wiring. The switch itself is unique to 1965 fog lights as is the engine compartment lights wiring. The current add on fog lights use the 1966 style harness assemblies and switch.
