Author Topic: No runs, or drips on the bottom, a point deduction?  (Read 7352 times)
Re: No runs, or drips on the bottom, a point deduction?
« Reply #15 on: September 10, 2014, 10:41:21 PM »
I've personnally been very happy using a syringe with thick needle.  I cover the floor, then squirt matching tinted epoxy above the area where the drips should be.  The epoxy runs down to the low points and drips down onto the temporary disposable floor cover.  Because of the waste on the floor I work from the inside out.
The thinks I like about this method is (1) less waste, (2) same material as floor, (3) same color throughout, (4) no rush, (5) I can survey the look and go back and add more strategically to add to the randomness if and where needed.
Offline Toploader
« Reply #16 on: September 11, 2014, 04:47:47 PM »
It's worth a thought. A once sloppy hasty assembly line routine has now turned into a process akin to an artist's work on his canvas...
76A-Y-D2-13H-72-6-6
Offline drummingrocks
« Reply #17 on: September 11, 2014, 04:53:20 PM »
That's exactly right.  It's amazing the lengths we go to just to replicate something that was slapped together on the assembly line.  It's the same with seam sealer, firewall sealer, etc.
« Reply #18 on: September 11, 2014, 05:57:26 PM »
I could find a way to complicate a grain of SALT!
« Reply #19 on: September 11, 2014, 08:50:06 PM »
How about a different spin?  While the factory method was certainly fast, and the particular process did not require a high level of skill, consider what it would take to replicate it exactly.  A moving assembly line, a "bath" of primer, spray nozzles with pumping and pipes/hoses to connect the dots.
So when we talk spray cans, syringe needles, and other alternatives, I think it is more of combining inginuity and frugalness.  I think the alternatives are less complicated in comparison to the original method.
Offline Toploader
« Reply #20 on: September 12, 2014, 05:06:02 PM »
Good point.
76A-Y-D2-13H-72-6-6
