Author Topic: 70 mach 1 front windshield moulding rivets  (Read 1697 times)
Offline rayms69
« on: April 27, 2012, 03:53:12 PM »
I am missing one, cant seem to find these little rivets. Anyone know where i can pick one up
10-26-1969 Dearborn 428 SCJ auto
Offline 7Lscjracer
Re: 70 mach 1 front windshield moulding rivets
« Reply #1 on: April 28, 2012, 01:16:12 AM »
I suppose you could wade thru the AMK catalog,
http://www.amkproducts.com/Catalog_PDF.htm
but for $8 minimum shipping I'd advise putting a list together.
Should be easier to go to your local fastener supply house and get an equivalent.
You'll have to consider a number of factors.
Rivits 101, check this info out: http://www.r-rivet.com/040~Product_Info/
« Last Edit: April 28, 2012, 02:30:34 PM by 7Lscjracer »
Bought May '81, sold Sept '20
Offline cobrajetchris
« Reply #2 on: April 29, 2012, 03:01:13 PM »
The original windshield molding retaining clips were not attached with rivits but a weld in stud that the clip slid on to. I guess if your missing one, a simple 1/8 inch pop rivet would work.
CHRIS KNOBBE
« Reply #3 on: April 29, 2012, 06:07:08 PM »
For service and to replace a broken stud on the assembly line, Ford used a screw, 376560-S100 8-18X3/8L truss head 3/8dia. This applies to 64 thru 68 and I see no reason not to use the same repair for 69 and 70. The bad news is that it is not available from AMK, but with the spec listed you might find a replacement.
(I'm across the street for pizza.)
Offline rayms69
« Reply #4 on: April 30, 2012, 12:58:21 PM »
yeah, not a rivet but thats what i would describe it as, i can see the hole with a piece broke off filling hole, i was thinking a screw, wanted to pass it through this forum for experienced opinions
