Author Topic: hood blkout  (Read 4059 times)
Offline 1970shelbyguy
hood blkout
« on: April 25, 2012, 11:51:58 PM »
removed my hood off my 71 429cj  sportsroof today- orig paint 47K mile car.  even though it was painted a dark color there seems to be a matte blk paint applied all along rear btm edge of hood.   also some paint drips visible-  drips indicate the hood was horizontal when painted. drips were under the ram air plenum. no touchups all orig.   also the argent strip applied to leading edge under peak moulding. never seen that before.
1970 gt500  grabber blue  june/69     1970  boss 302  metuchen  dec/69
Re: hood blkout
« Reply #1 on: April 29, 2012, 10:02:08 PM »
What you found is consistent with what I've found on 71. This helped hide the bottom rear edge of the hood, windshield washers and the bottom of the polished metal trim there. Also check to see if the rear (approx)  six inches of the fender lip is blacked out also.
From the 71 Cougar I'm currently trying to finish
« Last Edit: April 30, 2012, 07:39:27 PM by J_Speegle »
Re: hood blkout
« Reply #2 on: April 30, 2012, 10:43:09 PM »
thanks for the reply jeff-   have you seen the argent strip on leading edge of hood peak  before?.   probably blk if hood ram air treatment was blk.
Re: hood blkout
« Reply #3 on: May 01, 2012, 10:18:47 PM »
Would expect that since the idea was to make the area under the hood surface at the rear disappear to the eye those too would have the black out rather than use the argent but don't have a picture. Just a belief
Offline nham3407
Re: hood blkout
« Reply #4 on: May 02, 2012, 12:09:48 PM »
It was my understanding that the blackout on the rear edge of the hood above the cowl area was only applied to cars with lighter colored exterior colors.  When stripping the interior of my 4F Medium Lime Metallic non-functional ram air hood I did not notice any black on the rear edge.  I was not planning on painting the blackout onto my hood.  Does anyone know the colors the black would have been appklied too?
67 GT S-Code, San Jose, 06/67
72 Mach 1, Dearborn, 01/72
Offline nham3407
Re: hood blkout
« Reply #5 on: May 02, 2012, 03:13:19 PM »
This was copied from the 429 megasite:
http://429mustangcougarinfo.50megs.com/paint_info.htm
Hood Blackout on Rear Edge
This photo shows the black paint applied by the factory to the rear edge of light colored 71 Mustang hoods. (original and restored pics shown). The purpose of this was to keep the light color of the lower rear edge of the hood from being visible to the driver.
Re: hood blkout
« Reply #6 on: May 05, 2012, 01:11:20 PM »
prepping my hood last nite and came across a pile of insulation stuck inside back edge of hood.  wondered where all my  interior side panel insulation went to?  must have been busy the little buggers.
Re: hood blkout
« Reply #7 on: May 08, 2012, 07:24:34 PM »
Great site - unfortunately the example (new application) does not have the windshield washers and hoses installed prior to the black being applied :(
Re: hood blkout
« Reply #8 on: May 08, 2012, 08:41:24 PM »
hi jeff- so you're saying the washer squirters and hose hookup were attached prior to blk out application  i see the shadow in the yellow example .   you might be interested in my posting of a couple of pics of  my bolt in glass for a 70 gt500 date code is 9E  i'll post pics on the 65-70 shelby link  definately 9E  not 0E or 9k,l,m  BUT 9E !
Offline nham3407
Re: hood blkout
« Reply #9 on: June 08, 2012, 06:08:55 PM »
So the washer squirters and hose should be installed first before the blackout applied?
Re: hood blkout
« Reply #10 on: June 11, 2012, 07:34:49 PM »
That is what I've seen/found on 71 examples I've seen
