Author Topic: 67 S-code alternator mounting question  (Read 3755 times)
Offline 69bossnine
« on: April 17, 2012, 09:31:40 AM »
Hopefully someone can enlighten me on this... On our Metuchen-built '67 GTA, the adjuster-bracket mounts underneath the alternator, and there's a hole in the upper bracket that ostensibly would serve in mounting a smog pump above the alternator. But this car was never equipped with smog, sold new in Alabama. But everything matches the Ford illustrations for a smog-equipped car. We first restored this car when I was a kid in 1979 for Bill Gowin (some older guys may remember him and the car, silver-frost GTA coupe loaded-up with options that ran through all the MCA levels in the '80's). He rebuilt the original engine and provided it with the accessories for the restoration way back when, and we've not changed anything, just rebuilt and re-detailed the motor.
Our two other S-code '67's are un-restored, and they have a different mounting setup, with the adjuster bracket on top of the alternator.
Is the Gowin car wrong, and somehow got put together with smog-app parts? Or did non-smog cars get built both ways as another example of Ford random-ness and assembly-line-parts availability?
I'd ask Scott, but he's on vacation.. :)
« Last Edit: April 17, 2012, 09:33:13 AM by 69bossnine »
Re: 67 S-code alternator mounting question
« Reply #1 on: April 18, 2012, 12:55:41 AM »
f
First I would look at the upper bracket and check which engineering number is stamped on it. If it is a a C8 then it was replaced.You would typically only have the Smog pump alt bracket on a themactor car.
« Reply #2 on: April 18, 2012, 09:19:45 AM »
My dad has a 68 S code that was built in San Jose and delivered to the Denver DSO that has the same alternator bracket. He has owned the car for 15 years so someone could have changed it, it has made me wonder too. Marty
« Reply #3 on: April 18, 2012, 08:43:16 PM »
67 or 68 ?
« Reply #4 on: April 18, 2012, 10:07:31 PM »
That speed reading will get you every time my friend!  68 S code!
« Reply #5 on: April 18, 2012, 11:06:28 PM »
Yep I know all so well ;)   Lets see - you read S-code - alt- mount
See you in a little over a week
« Reply #6 on: April 19, 2012, 01:36:43 AM »
So which is it? 1967 Thermactor or 1968 Thermactor bracket? They are different and they both mount the alternator down low.
« Reply #7 on: April 19, 2012, 02:14:06 AM »
Hopefully he's checking and will get back to us so we can try and help
« Reply #8 on: April 19, 2012, 09:10:15 AM »
Sorry Jeff my bad I did not know that there was a 67 and a 68  version I get a look at dad's today.
« Reply #9 on: April 19, 2012, 10:52:58 PM »
Here is a picture of whats dad's 68 S code has on it. C6? can that be correct? Marty
« Reply #10 on: April 19, 2012, 10:57:30 PM »
Marty that would be a stretch  ;) The C8 version would be much more likely (on a thermactor car). I think you have the evidence to support the change out IMHO.
« Reply #11 on: April 20, 2012, 10:34:10 PM »
Definitely the 1966-67 style brackets (C6AE), in my experience with the two holes is the 1966 version.
For those that don't know, cars and light duty pickups, delivered in California 1966-67 often had thermactor smog systems.
