Author Topic: 289 K- Hipo  (Read 3593 times)
Offline ceswert
  • Silver Level Subscriber
289 K- Hipo
« on: March 29, 2012, 06:12:14 PM »
Looking for a 289 K code Hipo block for my 67 Shelby. Thanks!
67' Shelby GT 350 nm blue/4sp/#0089
07' Shelby Super Snake 725hp/white/#0073
71' Mach 1 429cj grabber blue/4 sp./ac
Re: 289 K- Hipo
« Reply #1 on: March 29, 2012, 10:50:28 PM »
Before anyone asks ;)
 Aug -Sept 66 would be what ceswert would like to find but surely would consider others. Short block or just block and caps
Just trying to help
Offline ceswert
Re: 289 K- Hipo
« Reply #2 on: March 29, 2012, 11:56:40 PM »
Thanks for the help Jeff! Richard now wants to keep both blocks and restore his matching one over time. He said he would help me out.
Re: 289 K- Hipo
« Reply #3 on: March 30, 2012, 12:58:27 AM »
Then your looking for only a short block since you will need the Hipo rods and crank at least to start out. Don't think anyone will care about the pistons and you can choice the cam of your choice
Offline ceswert
Re: 289 K- Hipo
« Reply #4 on: March 30, 2012, 07:58:24 AM »
Great, thanks.
Offline ceswert
Re: 289 K- Hipo
« Reply #5 on: April 24, 2012, 09:00:08 AM »
My contact in NY has located a short block. The Vin is 6F09K211188 or 99. The short block is a C5AF6015-E. He is going to magna-flex everything, use a master rebuild kit and have the block powder coated. I have asked him to take pictures of the build which I can post. I do retain some original parts I will use on the balance of the rebuild. I am now searching for the correct Holley 715 carb. Thanks for everyone's help!
Offline Skyway65
  • Gold Level Subscriber
Re: 289 K- Hipo
« Reply #6 on: April 24, 2012, 04:49:32 PM »
another one for someone else?? :P
http://nmi.craigslist.org/pts/2953177171.html
Gary Schweitzer
MCA #00181
Traverse City, MI
Re: 289 K- Hipo
« Reply #7 on: April 25, 2012, 12:03:14 AM »
........... I do retain some original parts I will use on the balance of the rebuild. I am now searching for the correct Holley 715 carb.
The 715 you got on the car should do ok until you can find a dated one  (to your car)  I would think. Only thing with its is that its a service replacement so that date is off
Are you going back with the headers or back to the original style cast exhaust manifolds?
Need a K code dist also unless you found one (would look for that before the carb)
Offline ceswert
Re: 289 K- Hipo
« Reply #8 on: April 25, 2012, 09:47:59 AM »
Hi Jeff,
That is a very good question. My goal is to restore this car to as original as possible. I do like the current headers though. At this point I am leaning towards original. Looks like stock exhaust manifolds are available. Thanks for the info on the carb/dist.
Re: 289 K- Hipo
« Reply #9 on: April 25, 2012, 04:49:25 PM »
keep in mind if you are wanting a factory look there are many other items that are painted black besides the engine block, some of which can not be powder coated. The thermostat to waterpump bypass hose comes to mind  ;) .
Offline ceswert
Re: 289 K- Hipo
« Reply #10 on: April 26, 2012, 12:34:25 AM »
Excellent point. Forget the powder coating. Thanks Bob!
