Author Topic: Holley 4150 Power Valve for 67 390 Auto???  (Read 1321 times)
Offline Angela
« on: March 21, 2012, 11:34:25 AM »
Given that Pony Carbs is no more, I do not know who to turn to for carb questions. Can anyone comment on the appropriate size power valve for Holley 4150 (9510-D list 3796) for '67 390 Automatic mustang applications? When originally rebuilt by Pony Carbs, a 5.5 power valve was installed. I am now going through the carb due to my stupidity of allowing fuel to sit in the carb too long. The power valve which cam with the Holley "renew" kit is a 6.5. I do not know how sensitive this application might be to the power valve size. As I understand it, the larger size valve will open sooner (i.e. under higher manifold vacuum). What I don't know is whether or not Pony Carb installed the 5.5 valve because they knew that was the correct size or if any valve in the 5-8 size range will work just  fine.
Help?
Offline Texas Swede
Re: Holley 4150 Power Valve for 67 390 Auto???
« Reply #1 on: March 21, 2012, 02:52:53 PM »
According to my 67 Shop Manual the power valve should be number 65, i.e. opens at 6.5 inches of mercury.
Texas Swede
Offline Angela
« Reply #2 on: March 21, 2012, 03:34:12 PM »
Thanks a ton! I must have completely overlooked this specification in my shop manual. I cannot recall if I checked the engine or carb section or both...
