I decided to rebuild my proportioning valve in my '66 Shelby. It was very cruddy-looking when I pulled off the attaching brake lines. I'm not surprised about this, since my car has probably not been running since the late 1970's. Anyway, I found a website (
http://www.stangerssite.com/brakevalve.html) that talks about rebuilding the Kelsey Hayes '65-'66 proportioning valve. But what it fails to mention is this. Once you take it apart and hone it and replace the seals (seal kits are available for around $25), you can put it back together, and reset the adjusting nut and sleeve. Of course, I am assuming that the inside bore of my proportioning valve is not badly pitted, and that I can successfully hone it. You are supposed to set this adjusting nut and sleeve back to a measurement that was taken before you take the proportioning valve apart.
But then I was wondering, there
must be specs. for the brake line pressure for the front calipers and the rear drum brakes. I have a Snap-On ABS brake pressure testing kit. When I hook up a brake line pressure gauge to the front disk brake line, and then hook up another pressure gauge to the rear drum brake line, I can read the specific pressure of both disk brake and drums. I would like to fine-tune my proportioning valve to the ideal line pressure from front to rear. My rear drum brakes have been rebuilt with stock brake linings...nothing special. I have rebuilt my front KH disc brakes myself using basic brake pads and stainless steel piston replacements. So, my question is this:
WHAT IS THE IDEAL BRAKE LINE FRONT AND REAR PRESSURES- FOR A '65-'66 MUSTANG OR SHELBY WITH FACTORY FRONT DISC BRAKES AND REAR DRUM BRAKES? Any ideas on this would be much appreciated.
