Author Topic: '68 390 PS hoses  (Read 3674 times)
Offline Oz390
'68 390 PS hoses
« on: March 06, 2012, 04:22:05 AM »
Finding it difficult to get correct hoses for a '68 390.  Most short control valve pairs sold as one-size-fits-all have one very curved end, one almost straght and do not appear to be correct.  My old ones had two short-ish stubs, both with slight curves.
Perssure line, pump to insulator.  Similar issues.  Too long and can not be correctly oriented to vertical, per FAM.
The two feed/return lines at the control valves, tubes pre-bent in such a way as to make it difficult to align them per FAM, tight to the housing to be clamped in place, and hoses too long or too short to get to the insulator without really having to force them in place, just do not seem right...
Anyone got hoses that fit a 390 without a struggle on an OEM style setup??  Looking for "correct" (ish)  repros, as NOS are way expensive, if you can find them....
« Last Edit: March 06, 2012, 06:52:24 AM by Oz390 »
8R03S : 76A I 2A 15M 72 5 U
Offline TLea
Re: '68 390 PS hoses
« Reply #1 on: March 06, 2012, 08:17:17 AM »
Have you tried these?
http://bluedotspecialties.com/
Not 100% but pretty good
« Reply #2 on: March 06, 2012, 09:23:09 AM »
+1  Marty
Offline Oz390
« Reply #3 on: March 06, 2012, 04:17:30 PM »
No, just found them after some searching.  Have some Shaefer (sp?) but have two of some hoses and they don't even match each other, let alone fit.
The blue dots ain't cheap ($200 for the HP hose! ouch).  But may bite the bullet and buy a set and see, as the others don't cut it...
Thank!s
« Last Edit: March 07, 2012, 03:02:42 AM by Oz390 »
« Reply #4 on: March 06, 2012, 07:25:26 PM »
I think you will find the blue dot hoses are far superior to any of the other so called reproduction P/S hoses. Almost every car needs them by now. I have found the blue dot ones the most faithful to the original design and because of that much less frustrating to be installed compared to the others on the market.To orient the pressure hose off of the back of the pump in a vertical position it takes two people for the best results. One to hold the hose in the correct orientation and the other to tighten the lower fitting and maintain proper position of the lower pressure hose . It is difficult because the hose wants to twist on you. It takes two hands ,one  to tighten the fitting and another to not let the lower pressure hose from the valve to the junction hang down . without a third hand it is difficult  maintaining the upper hose in a vertical orientation while all of the tightning is going on all at the same time. The lower pressure hose is supposed to be parallel to the ground.  That is why it is a lot less frustrating with two people.
Offline Oz390
« Reply #5 on: March 07, 2012, 03:14:24 AM »
Mian pressure line, pump to insulator.
One vendor shows this as "correct"
http://www.cougarpartscatalog.com/ps9cs.html
Blue dot this
http://bluedotspecialties.com.penpubwebs.com/merchant.mvc?Screen=PROD&Store_Code=bluedotspecialties&Product_Code=PS93909&Category_Code=Mustang
Which one is right, with or without wrapping?  Tinikng the wrapped may be 69, and not for 68, due to the number?
« Last Edit: March 07, 2012, 03:16:14 AM by Oz390 »
Offline TLea
« Reply #6 on: March 07, 2012, 08:43:51 AM »
Wrapping didn't start until 69. The Blue Dot listing shows the armour wrapped as correct for 68 and up CJ which is incorrect. 68 CJ and 428 PI used the same as 390 without armour
« Reply #7 on: March 07, 2012, 11:03:24 AM »
The c8za hose was used up till dec 68 on 69 cars then ford went to c9za hose with the wrapping same time they changed to bigger ps pump pulley & longer belt. Dont blue dot make a c8 version pump pressure hose as they have always been hard to find.
« Last Edit: March 07, 2012, 11:05:38 AM by specialed »
« Reply #8 on: March 07, 2012, 01:20:30 PM »
There were 3 different length upper pressure hoses (back of pump).   C7 was longest ,C8 a little shorter (Blue Dot makes both marked hoses but use the 68 length for both) and C9 with the wrap is the shortest and best fitting because of length  (although not technically correct on 67 or 68)  of the 3.
Offline Oz390
« Reply #9 on: March 08, 2012, 05:42:43 AM »
Bob, would you know the different lengths?  Shaefer has agreed to make a set for me off my old ones, but that one is obviously a old repro,a nd too long.
They will send them to me for test fit, then make me up 3 sets for the 3 big blocks.  So, hopefully, some good fitting hoses come out of it for other big block owners at a preice a lot less than BlueDot, and hopefully ver close as the Shafers looked Ok to me, but I had no OEM to compare to...
Offline Oz390
« Reply #10 on: March 08, 2012, 06:22:15 AM »
On the routing of the lines from the control valve to the insulator on a 68 390.
Larger fitting return hose (3A713) routes above the smaller fitting pressure tube (3494) along the body of the valve and both are clamped to the valve with a hose clamp, correct?
Offline rockhouse66
« Reply #11 on: March 08, 2012, 08:27:33 AM »
One of the issues with aftermarket hoses has been they don't get the bend right at the pump and they use a smaller 3/4" wrench size fitting instead of the correct 13/16" like an original.
'66 GT FB
Offline TLea
« Reply #12 on: March 08, 2012, 08:53:55 AM »
correct. I have several original 68 hoses, tell me how you want them measured
