Author Topic: convertible seat access holes, can anyone explain....  (Read 3817 times)
Offline Oz390
« on: February 29, 2012, 05:23:17 AM »
Why the two big ones with the special metal "clamp-in" plates... they go near the ebrake cables but really make no difference I can see for any maintenance, access, or other obvious use....
Why the extra cost for fab/assembly (and especially for the repro plates!) for a part that seems to have little function???
8R03S : 76A I 2A 15M 72 5 U
Re: convertible seat access holes, can anyone explain....
« Reply #1 on: February 29, 2012, 09:24:12 AM »
The larger holes were to give access to rout the E-brake cables through the bottom crossmember. Yes those Scott Fuller reproductions are pricey but they are perfect. Marty
Offline TLea
« Reply #2 on: March 01, 2012, 08:46:04 AM »
I've always wondered about them too as its not that difficult to route cables without the holes. As far as cost even though its expensive to reproduce quality accurate parts now that metal plate was probably 2.6 cents to make originally
« Reply #3 on: March 01, 2012, 10:01:56 AM »
I have seen the big holes on other Ford's built during that time.  Maybe a cost saving?  Don't Cougars have 4 big holes on each side?
« Reply #4 on: March 01, 2012, 06:55:08 PM »
+1 at least some years
« Reply #5 on: March 01, 2012, 10:44:02 PM »
Boy at $135 a set that's some big money to fill them holes!
« Reply #6 on: March 01, 2012, 11:26:04 PM »
I don't think the Cougars had covers, Jeff can correct me if I'm wrong.
It's plain to see in that picture that there is absolutely no benefit of the larger holes being on the rocker end of the metal section.  Which would lead me to think that it was done for cost savings on sheet metal.
IIRC, Mustangs and Cougars shared some components.
Offline Oz390
« Reply #7 on: March 02, 2012, 05:06:50 AM »
Yeah, from 2.6c (OK 5.2c for two!) to $135 is a bit more than the appreciation of the cars!
I had to put a piece of cloth over the tab before grabbing it with pliers to bend it in place so I wouldn't scratch the pricey parts!!!  (that no one will ever see!!!)
And on "Which would lead me to think that it was done for cost savings on sheet metal."  It really wouldn't save on initial cost of the sheet, as the were probably punched out during forming, not sure how much "savings" the extra scrap going to recycling was back-in-the-day...
« Last Edit: March 02, 2012, 05:09:21 AM by Oz390 »
« Reply #8 on: March 02, 2012, 10:28:04 AM »
Take into consideration how thick the sheet metal is on this piece.  I don't think it is unreasonable to suggest it was a cost savings approach.
Offline Oz390
« Reply #9 on: March 02, 2012, 06:12:48 PM »
Looks to be more required for access to get the floor plugs in up above.  Had to cut at least a ~1 1/2" hole to fit them in, but that leaves no access to install, so a slightly larger hole to get in there and fit them.  There would be some added scrap value in the slightly larger items...
« Reply #10 on: March 06, 2012, 12:41:33 PM »
jeffs photo is 69 & up all 4 holes same mustang & cougar.
Offline Scott Fuller
    • Scott Fuller Reproductions
« Reply #11 on: March 06, 2012, 07:53:04 PM »
I think NPD sells a cheaper version if you don't care about the correctness.
Scott
68 "135" Mustang, 68.5 Blck Mustang CJ Cnvrt, 68 Rd HCS (fact 428), 68 Ac Bl Mustang GT Cnvrt, 68 Ylw GT500KR Cnvrt, 68 Hlnd Grn GT500KR Cnvrt, 68 Gld G.T. 500 Cnvrt, 68 Ryl Maroon Mustang Sprint Cpe, 68.5 Hlnd Grn Fstbck, 68.5 Ylw Mustang Fstbck. Visit my website www.scottfullerreproductions.com
Offline Oz390
« Reply #12 on: March 06, 2012, 10:26:15 PM »
I bought your parts, they are great!   Just a comment on the escalation and wishing the cars went up as much (I could retire then by selling a few!)  :o
The NPD are just a plastic/rubber stopper...
« Reply #13 on: March 06, 2012, 11:12:13 PM »
There are metal covers that are plain, but like Scott says, they basically just cover the hole and aren't remotely correct.
