Author Topic: Restored 1966 6 Cylinder Engine  (Read 12064 times)
Offline Pete Bush
Re: Restored 1966 6 Cylinder Engine
« Reply #15 on: February 29, 2012, 07:22:10 PM »
Dave,
If you don't have any success locating one, let me know. You're a pretty resourceful guy. You can borrow mine and perhaps make a mold and casting?
Offline Turnall
« Reply #16 on: February 29, 2012, 07:22:39 PM »
A bit off topic but I noticed the sand blaster in the back of the garage, (I have the same unit).  Do you collect the sand somehow?  If so, would you mind sharing how?  Thanks for the info and again, very nice looking I6...
Allen
« Reply #17 on: February 29, 2012, 08:47:25 PM »
It looks like Dave has an Eastwood cabinet stuck in the back. I use a cabinet sold by TP Tools www.tptools.com and they have a vacuum attachment for used media, about $300 for their VAC 40 model. I prefer glass beads as a blasting media, TP Tools Scat Magic, as it is about as abrasive as you can get legally. I've used it to cut notches in glass for clearance. For a less abrasive finish I lower the air pressure. Glass beads are some nasty abrasive and the equipment shows the wear, I put in my second replacement blower last week after about 15 total years of use. The used media collects in the bottom and you need to empty it out. I was not paying attention and I have about 8 gallons to get rid of. My last batch of blasting was a lot of around 110 items of hardware plus a couple of 66 filler pipes that went to my plater on Monday for clear zinc plating. I have a second lot of clear zinc to do and a lot of gold zinc pending.
We now return you to the original post.
Offline ChrisV289
« Reply #18 on: February 29, 2012, 10:10:25 PM »
Terrific looking engine...I do have a question though...At what point back in the day was the exhaust manifold placed on the car?  I can see why the top would have blue on it when spraying the valve cover but why wouldn't the bottom have blue on it as well when spaying the actual block or was the block already painted at that point?  Just something I was wondering...
2009 V6 Mustang Coupe
« Reply #19 on: March 01, 2012, 08:20:03 PM »
It's been long standing barroom chatter that many judges would build a Thoroughbred 6 cyl car one day.  Although, I don't think it would be any easier than a V8 car.  There's so many details to consider.  Think it was discussed once that there are many more differences between an I6 and V8 car than between a K code and C/A code car.
One thing the Jeff stressed in one of his seminars (a long time ago in a Galaxy far, far away) was the more items on a car, the more items that are judged and the more potential for points deduction. Putting it another way, a "Plain Jane" I-6 has a better chance for a top score than a fully loaded 428SCJ Mach I.
Offline C5ZZKGT
  • Gold Level Subscriber
« Reply #20 on: March 02, 2012, 11:58:23 AM »
-What a GREAT looking engine!! Keep up the good work!!
Offline buckeyeresto
« Reply #21 on: March 02, 2012, 07:04:39 PM »
Looks good any indication that the alt fan pulley was blue and also the engine is missing the exhaust hanger bolted to the block
Offline Twilight65
« Reply #22 on: March 02, 2012, 08:15:53 PM »
The original alternator had been replaced. Was the exhaust hanger bolt part of the clamp that went around the exhaust?
Dave
Offline mtchstng65
« Reply #23 on: March 08, 2012, 07:55:32 PM »
Killer looking engine, can't wait to see it back in the engine bay...
1965 Fastback, 1966 Fastback, 1986 GT Hatchback (Unrestored), 2003 Mach 1,
2008 Shelby GT500,
641/2-66 Concours Mustang MCA Certified Judge & 1965-1966 Shelby MCA Certified Judge
www.showmemustang.com
« Reply #24 on: March 09, 2012, 02:12:52 AM »
Looks good any indication that the alt fan pulley was blue ..........
Think that would be a reach unless we had other examples around the same time. Seems like its about 10,000 to one chance especially given its a 66 and San Jose car
Offline cobrajetchris
« Reply #25 on: March 09, 2012, 01:15:24 PM »
I couldn't agree more with that statement. I am restoring a highly optioned 42CJ ram air, with a/c p/b p/s and all the emissions to boot. It's breaking the bank getting this car together. It is amazing how many different parts are needed to put this car back correct and not the easiest engine to work on. I have to admit the only thing I am jealous of the old camaros are the subframe and the integral power steering as this is a much better design in my opinion.  CHRIS
CHRIS KNOBBE
Offline Twilight65
« Reply #26 on: March 12, 2012, 07:49:12 PM »
OK I didn't have this hanger but found one @ Millers Obselete and the clamp @ Ford NOS. I reviewed pics I've taken over the last couple of years from shows and looks correct (though it may be upside down?). I'm just wandering about the clamp as the MPC call for Part# A9AA-5A231-A.  I purchased the part but package looks like its earlier than the car. Would the same part number evolved over the years without changing the suffix letter? Does anyone know what the correct clamp should look like?
Dave
Online ruppstang
« Reply #27 on: March 12, 2012, 09:51:15 PM »
I have a original one or two laying around. Marty
Offline Pete Bush
« Reply #28 on: March 13, 2012, 07:26:57 AM »
Dave,
My engine still has the part that's bolted to the block. It looks similar to yours, but hard to tell as it's behind the exhaust pipe. The orientation is correct. Mine is currently blue, but a PO might have done that when the engine was repainted many years ago.
My clamp is missing, so I can't help with that. Maybe this accounts for why the front engine boss that the exhaust manifold was bolted to was broken on my car. Too much movement of the exhaust pipe. I had to reconstruct the boss out of J-B Weld. It looks pretty good. And seems to be holding up just fine. Hard to tell it was even repaired.
Offline Twilight65
« Reply #29 on: March 13, 2012, 05:52:31 PM »
Marty, Can you post a picture.
Dave
