Author Topic: Restored 1966 6 Cylinder Engine  (Read 12568 times)
Offline Twilight65
  • Gold Level Subscriber
« on: February 27, 2012, 09:02:18 PM »
OK finally finished the 200 CI for my 66 Sprint Convertible. I took a couple of liberty's but looking for critique from the experts.
Dave
PS I included 1 before resto pic
Offline Turnall
Re: Restored 1966 6 Cylinder Engine
« Reply #1 on: February 27, 2012, 09:08:13 PM »
I'm not a judge, but I've got to rebuild a 200ci for my 66.  Hope it turns out half as good as that!  Nice...
« Reply #2 on: February 27, 2012, 09:11:49 PM »
Looks really nice, good job.
Only a few things:
-Need to dull down the vacuum and fuel lines
-Valve cover bolts should be blue, at least some of them
-Valve cover gasket edges should be blue
-Never seen that marking on a PCV hose, but I guess we have discussed before
-Never seen an ink stamp number on the bottom of an oil filter either
-Trim down the 'coil' tag on the wire
Offline Ivygreen65
« Reply #3 on: February 27, 2012, 11:17:48 PM »
Dave,
Great work.  Charles mentioned a few minor things to correct, but a beautiful 200 with a lot of details that will definitely set your car apart.
« Reply #4 on: February 28, 2012, 12:44:55 AM »
Now that's blue (see starter cables post) and the rest looks good. Try a couple of pictures in natural light without direct sunlight or camera flash. That might satisfy Charles observation of the fuel lines. He's correct about the valve cover bolts, gasket and filter, all blue - and be sloppy, the factory painting was done by a hungover union worker eager to go home.
« Reply #5 on: February 28, 2012, 08:54:23 PM »
Not sure if they reproduce them  but here is a shot showing the original location showing where they were applied. Basically only the adhesive remains
These were from a 51K mile 6 cylinder that was at the Washington MCA show
Email me directly - got at least one additional shot with marks for you ;)
As for the oil filter with the part number - only seen two marked that way. One on a 68 and one on a 65. Can't confirm if they were original
« Last Edit: February 28, 2012, 10:13:31 PM by J_Speegle »
Offline Pete Bush
« Reply #6 on: February 29, 2012, 07:33:06 AM »
Dave,
That's the prettiest thing I've ever seen - and work I can only aspire to.
Amazing how much the blue color fades over the years...
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #7 on: February 29, 2012, 09:18:45 AM »
Sort-Of makes me wish my C-Code was a 6!  No, Bryan didn't say that!
66 Metuch Conv
Nightmist, Std Blu Int
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #8 on: February 29, 2012, 09:20:30 AM »
Dave,
The faded blue looks almost like the blue used on a 64.5 260
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline Jack65K
« Reply #9 on: February 29, 2012, 10:26:27 AM »
For some reason the pictures do not open on my computer but I have seen the engine in person and it is great!!!
Jack
65 K Code Coupe, Vintage Burgundy/White Vinyl Top & Black Interior
04 GT Convertible, Redfire Clearcoat/White Top and Oxford White Interior
« Reply #10 on: February 29, 2012, 11:38:48 AM »
It's been long standing barroom chatter that many judges would build a Thoroughbred 6 cyl car one day.  Although, I don't think it would be any easier than a V8 car.  There's so many details to consider.  Think it was discussed once that there are many more differences between an I6 and V8 car than between a K code and C/A code car.
« Last Edit: February 29, 2012, 11:42:18 AM by caspian65 »
Offline 64rustang
  • Holland Patent, NY
« Reply #11 on: February 29, 2012, 02:13:10 PM »
Very Nice!  Being a 6 cylinder owner, I'm glad to see one detailed so nice!
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRAN
 65A        D        46       27E      22       3        6
VEHICLE WARRANTY NUMBER
5F07U148XXX
Offline Pete Bush
« Reply #12 on: February 29, 2012, 03:02:09 PM »
Say Dave,
I don't see it in your pictures, but I know you and I talked about it; did you ever find the plastic spacer that goes between the carb and air cleaner?
Offline Twilight65
« Reply #13 on: February 29, 2012, 06:59:37 PM »
Say Dave,
Hey Pete,
Haven't found one yet. I have called a lot of places and also quite a few carburetor repair shops also with no luck. But I haven't given up yet.
Dave
Offline Twilight65
« Reply #14 on: February 29, 2012, 07:17:17 PM »
I just wanted to thank everyone for the comments and support. Along with what Charles was saying, this hasn't been easy as parts and information for a 6 cylinder are hard to come by. I want this car to be as correct as possible. I got lucky as this car had so much orignal tags and markings on it. The transmission is done also so I will post pictures soon. I just got the car back from the sheetmetal shop and its off to the body shop now.  Those NOS red oxide quarters set me back a little but man they fit great. Won't be a Thoroughbred but as close to original to what I can afford.
Thanks Again,
Dave
