Author Topic: Grey Coil Springs??  (Read 3266 times)
Offline BBs70fastback
Grey Coil Springs??
« on: February 25, 2012, 02:20:24 PM »
Here are pictures of my coil springs before and after evaporusting, off my 1970.  I assumed I would find a lot of black paint under the rust, but did not.  Just found dark grey, phosphate like color.  (note that I did have some black residue after evaporusting, but it seemed like black liquid from the de-rusting process, not paint like I have seen on other parts).  Another post mentioned that all the black paint would have flexed off over the years, and so even if you didn’t find black paint, they should be black.
Interesting how the paint markings held up better than anything else.  I flecked off the paint markings to check for black underneath and found none.  Would the dark grey springs be proper/possible for a 1970 Dearborn??  I also assumed the paint markings go on after the black paint??  If the paint markings went on first that might explain the absence of black under the markings.
If the dark grey is correct, was that a phosphate finish or something else?  (not against painting them black, just trying to be accurate).
Thanks, Barry
First Restoration - going for original driver
1970 Sportsroof 302 2V, Dearborn, built June 17, 1970, power steering, Auto, A/C, Y code Chestnut Metallic, standard black interior
Re: Grey Coil Springs??
« Reply #1 on: February 25, 2012, 07:08:45 PM »
The phosphate coloring is likely IMHO the results of the oil quenching process used in hardening steel for use on parts like these. What you found is pretty typical from the ones I've cleaned and found over the years. Had at least one worker describe the front coil springs as being phosphate in color during a discussion
The color can be a very dark gray to an almost black - this may have differed slightly on how dirty (how used) the oil bath was when the springs were dipped.
I've used the liquid gun bluing for years for this purpose - followed by a protectant oil while others use things like Insta-Black.
Example (Yes zert fitting were removed before it was done)
« Last Edit: February 25, 2012, 07:17:56 PM by J_Speegle »
« Reply #2 on: February 28, 2012, 01:50:44 AM »
Thanks so much for the response and picture!  Do the paint marks go on before the bluing or insta-black?
« Reply #3 on: February 28, 2012, 02:20:54 AM »
Like with any part (and how it was originally) the finish of the part comes first and then any pretty ;) paint mark. Then you can choose to oil or protect it in your own way
Offline svo2scj
« Reply #4 on: February 29, 2012, 01:45:53 PM »
MAN !  I would "gun blue" over those marks - they are nice !!   (So many "over restore" with incorrect strokes or worse (tape and spray) )
Mark
P.S.  You don't always see 100% of them anyway
« Reply #5 on: February 29, 2012, 10:59:50 PM »
Good idea - maybe evapo-rust the springs and then recolor them
