Author Topic: D code - Starter Cable bracket picture  (Read 12676 times)
Re: Starter Cable bracket picture
« Reply #15 on: February 25, 2012, 11:53:57 PM »
I actually need one of those too.  Someone was making those in their garage and getting $35 dollars a pop for them.  I can't remember if I saw them here or over on the Vintage Ford Mustang website.
According to the 64 Electrical Assembly Manual (which we know is a work of dubious authenticity), AM0003, pg23, the clamp is part of the battery ground cable assembly, C2OF-14301-B, and its part number is at best unknown, and if you go to page 24 of the same book, view B shows the clamp installation for the solenoid to starter cable. (Whew.)
Offline Twilight65
  • Gold Level Subscriber
« Reply #16 on: February 26, 2012, 04:22:31 PM »
John, Here's a pic of my 65, I believe is correct.
Dave
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #17 on: February 26, 2012, 06:58:49 PM »
I've got my 66 just like yours, Dave, with two,  but... I THINK there's only suppose to be one.
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #18 on: February 26, 2012, 08:04:04 PM »
I think the determination for one bracket or two depends on the cable assembly part number. If it's a C5xxx, it requires two, if it's a C6xxx, it requires one. The transistion date is sometime in late 1965 or early 66 and probably is plant specific. My 66 "K", San Jose Oct 65 build, had the C5xxx cable with two brackets. The cable assembly was made in Canada and the brackets and insulator (and woven sleeve) were part of the assembly and Ford service apparently did not stock them separately.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #19 on: February 26, 2012, 09:13:34 PM »
OK,  I stand updated!
66 Metuch Conv
« Reply #20 on: February 26, 2012, 09:19:19 PM »
I think the determination for one bracket or two depends on the cable assembly part number. If it's a C5xxx, it requires two, if it's a C6xxx, it requires one. ..............
Here is an original example that does not match that pattern (5F07A270685)
Offline john_simms
« Reply #21 on: February 26, 2012, 09:41:10 PM »
Thanks all for the information and pictures.
Offline mgmradio
« Reply #22 on: February 26, 2012, 10:39:27 PM »
Jeff that is a picture from my Aug 64 A code.
  Mike
« Reply #23 on: February 26, 2012, 11:18:56 PM »
That's a nice shiny bracket on what looks like blue painted 65, and - need I go on?
« Reply #24 on: February 26, 2012, 11:55:56 PM »
The engine is black, what are you seeing that is blue?  The car only has 4,500 original miles.
« Reply #25 on: February 27, 2012, 12:51:08 AM »
What I see is the blue paint on a black engine.
« Reply #26 on: February 27, 2012, 01:03:53 AM »
Jim,the color on my monitor must be off some because I can't distinquish blue paint anywhere . It all looks black. Some areas are shinier then others but still appears black. Would you mind explaning where you are seeing the blue paint?
Offline bryancobb
  • 2009 Ridn' Around
« Reply #27 on: February 27, 2012, 06:16:20 AM »
OK MY MIND IS CHANGED.  There should only be one.
66 Metuch Conv
« Reply #28 on: February 27, 2012, 10:28:23 AM »
I can assure you 100%, without a doubt, that there is no blue paint on this engine.  I've spent considerable time observing this car.  It's a great reference piece that illustrates a lot of assembly line transition components from generator to alternator production.
In regards to the "shiny" bracket, that is simply a consequence of the ultra low mileage of this car and I can also assure you that the bracket is original.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #29 on: February 27, 2012, 10:47:39 AM »
My 66 is NOT original.  The clamps are repops.  There is two, and should only be one.
I can't remember if I replaced the cable with a repop or not, I think so.
BUT THE HEAT SHEATH IS WHITE WITH A BLACK STRIPE ON MINE AND IT IS ORIGINAL.
66 Metuch Conv
